Question about Audiovox New Original FPE2000 Remote Control
Can you program a fios remote for an audiovox model FPE2000
The volume for the remote does not always respond can I program my verizon fios remote to program this audiovox modelFPE2000
Progam phillips RC144 remote for verizon fios
the remotes usually to program combos ...but you may want to try the dvd ...and vcr codes ...as well
May 22, 2010 | Philips 19MDTR20/99 19 in. TV/VCR/DVD...
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
Dec 07, 2009 | Televison & Video
Cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
May 23, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Mar 31, 2009 | Vizio L32 32 in. LCD HDTV
I have tried to program my FiOS Verizon remote control to recognize my Proscan HD TV so that I don't have to use two remote devices. I don't like using two remotes and my Proscan remote control is so...
Thank you. I did solve my problem with some diligence. The instructions from Verizon were correct. I realized that there are two buttons on the Verizon universal remote that look alike - the "play" arrow and the "fast forward" double arrow. Once I used both of these buttons in the proper sequence, reprogramming the TV remote with the new code worked.
Mar 19, 2009 | Proscan 32LA30Q Television
Need remote codes to enter into my verizon fios remote
what kind of equipment is it? cus you can go to verizon.com go to fios tv then installation then support and click on remotes then get codes for yada yada yada/
Oct 23, 2008 | Broksonic CCVG297 9 in. TV/DVD Combo
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
Audiovox VE920 with Verizon FIOS
does it have a box on it? where verizon is already digital ready all tv's need a box around the house. if you need a box or technical help call the office at 888-553-1555
Aug 22, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Audiovox New Original FPE2000 Remote Control Logo
22 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
