Question about Standard Horizon Cp300 GPS Receiver
Troubleshooting radar turns on but will not detect anything. It does its 90 sec warmup, goes to STANDBY ... I press ENTER, but still will not detect. I tried auto calibration.... no difference. Adjusted GAIN, still no improvment
Lowrance Troubleshooting
do you have radar turned on inside the unit go to menu click on functions scroll down to radar see if the round circle is blue high lighted if not turn it on
Oct 27, 2013 | Boating
I have a Sharp DT400 projector. I replaced the lamp, and the unit powers on, and displays a picture during warm up but only for a few seconds. The lamp indicator and power lights go back to red and unit...
If you try to turn on the projector a fourth time without replacing the lamp, the projector will not turn on.
Press ON, INPUT, UNDO, left arrow, ENTER and right arrow on the projector in order, and then press ON.
The lamp 0000H is displayed on the lower left of the screen.
Mar 26, 2011 | Sharp DT-400 Multimedia Projector
Hi, I have a 37lc46 LG LCD which takes ages to start. When I press the power button the standby light goes off for about an hour, when it comes back on again I have to continue pressing the remote power...
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Cobra radar detector
Police usually do not leave their radar guns turned on all of the time. Indeed, most police officers prefer to use the "instant-on" technique to nab speeders. Instant-on works by leaving the radar gun in standby mode (no radar emissions) and then releasing a trigger button to instantly turn on the radar gun to measure a vehicle's speed.
You can check to see if your radar detector is detecting radar by putting it in Highway mode and then driving to a shopping center or other businesss location which has microwave radar automatic door openers. You should get either X band or K band alerts for these microwave automatic door openers. If you do not get any alerts for these door openers, and after having checked a few other locations which have microwave automatic door openers, then this would indicate that your radar detector is defective.
Apr 20, 2009 | XRS 9440 Radar Detector
RE: life of the radar magnetron
i have a furuno 1700 radar ,when i switch it on it goes to stand by ,when i press the standby button you can see it scanning but no land appears cheers alan
Mar 18, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Questions
Ku is a band of radar used in some places by law enforcement. It is not used everywhere and can be a pain if it goes off for no reason. I recommend consulting your manual and turning the Ku band off if it is not used in the area in which you live. This will enable your detector to become more reliable for when you are being "zapped" by law enforcement
Pop is a way of using radar where the officer turns his radar on and off quickly. As a car approaches, they will turn the radar on long enough to get a speed reading, then immediately turn it back off to avoid detection by civilian radar devices. Some of the newer models of radar detectors have a feature which detects pop radar.
Every electronic device emits a frequency. Vg2 is what law enforcement use in states where radar detectors are illegal to identify whether a car is using a radar detector. The newer version of vg2 is called spectre and accomplishes the same thing. Some radar detectors can pick up on vg2 and spectre so the owner can turn the detector off before they are detected by law enforcement.
Nov 27, 2008 | XRS-757 Radar Detector
Don't work
Try turning your inteli-mute off. If the inteli-mute (I-mute) is set with the RPM's too high it won't detect radar because the detector thinks you are traveling at a slow speed and detection is unnecessary. If your detector begins working, consult your owners manual to reset the I-mute limit if you want to use that option.
Aug 23, 2008 | XRS-757 Radar Detector
Early Warning EW-3400 Radar Detector Digital Compass Calibration??
I looked at another simuilar Detector and read on Digital Compass Calibration and through the process of elimination found that if I Press CITY for 3 sec.'s COMPASS CALIBRATION showed on the display. Then it says TURN YOUR VEHICLE SLOWLY 2 TIMES to CALIBRATE. Then press the CITY button to complete the calibration. Done. It worked my Early Warning EW-3400 Radar Detector's Compass is now Calibrated.
Thanks for asking.
May 11, 2008 | EW3100 Radar Detector
Troubleshoot
You should try to find out what type of radar devices your police uses.ESD7000 model does not support some devices such as Ku band radar signal, but it should detect all laser signal.Laser signal is often jammed by sun light.If your police uses radar detector detectors VG2 it will force your detector to hide from it making it invisible for detecting.Try talking to someone who has other type of detector that works in your town.It is possible that you will be forced to buy another model.
Feb 16, 2008 | ESD 7000 Radar Detector
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Standard Horizon Cp300 GPS Receiver Logo
16 people viewed this question
Top Standard Horizon GPS Experts
Steve
Steve
Mister Danger
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
