Question about HP Designjet T1100ps Printer
HP designjet t1100ps error 79:04 - HP Designjet T1100ps Printer
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
  • 96 Answers
SOURCE: The HP DesignJet T1100ps printer has a 79:04 error
hp will never tell you but this error is a kind of a catch all error basically the service manual says to reload the firmware. check the file you are sending. i have seen a bad file cause this error. hope this helps.
Posted on Oct 01, 2009
SOURCE: HP 800 designjet plotter Error Message 21:10
need to replace service unit
Posted on Mar 22, 2010
  • 217 Answers
SOURCE: hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Posted on Jul 29, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: HP designjet t1100ps error 21:13
This is a service station error indicating that the printer could not move the pirnthead mechanism over the service station. First check to see if there is anything in the carriage path such as a piece of paper blocking the carriage. If there is not then it is likely a bad service station that will require replacement. Always try powering pirnter off then on to see if it was temporary error.
Posted on Mar 21, 2011
How to install New firm ware in new hard disk printer hp designjet T1100Ps
When you installed the new hard drive, was it purchased from HP as the hard drive for the T1100ps, or did you install a generic hard drive like for a laptop?
HP uses a special formatting on their hard drive with its own operating system with the latest firmware already installed (not windows o/s), so just installing new firmware will not work...the plotter must be on and in a ready state to receive the firmware update.
Sep 24, 2013 | HP Designjet T1100ps Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Replace hp designjet t1100ps hard disk
Designjet T1100ps -Q6687A.
08:11 error. The formatter is okay but the hard disk is bad. How can I load the system software in a blank hard disk or try to clone
Apr 28, 2012 | HP Designjet T1100ps Printer
HP designjet 90 error code: 22.10
System Error: 22:10
Ink Supply Station failure.
Corrective Action: Replace the Ink Supply Station
(The Ink Supply Station is the mechanical part under the ink cartridges.)
Jun 13, 2011 | HP Designjet T1100ps Printer
Error 8:11 HP Designjet T1100ps 44in PS3
Error indicates Formatter,Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part..
d4wd6icgpc9laaaaaelftksuqmcc
nloqafiqpfr0pqy6fgsl6z+nlcjwrqeuxlt5siey8sjpc+feblil6+xgwjruzafracof0e359teuwi1ozhlmhrx0xfmcd+bfeilmn5l+ppik2hpic6wgwvpqfwee1yw0nvg1qi9vzo58bnigp4octvkvtsy87834sjn6odbsmoha2eycmv8comsjb7raqh4aaaaasuvork5cyii=
May 03, 2011 | HP Designjet T1100ps Printer
Hi hp designjet t1100ps plotter showing error code 86:01, paper jam. but physically there is no paper or obstacle in print area. carriage block also moving one time right to left then the error code is...
This error can be caused if there is anything blocking the movement of the carriage. I just had a client with this problem on Tuesday and it turned out that they had opened the print head cover and had not closed it properly. This caused the metal latch to block the movement of the carriage. I would check that first, as well as look for any small bits of paper that may be blocking the complete movement of the carriage.
Apr 01, 2011 | HP Designjet T1100ps Printer
08:11 error in hp designjet t1100
I had this code recently, and solved it cleaning the contacts pins in the formatter whit 2000 sand paper (could be pencil rubber) and reseating it.
Oct 01, 2010 | HP Designjet T1100ps Printer
HP Designjet T1100ps Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
