Question about VinoTemp 32-Bottle Wine Cellar - Stainless-Steel
I have a 18 bottle wineenthusiast refrigerator And i orden the control Board that Was damage, but they sent me the 32 bottle refrigerator control board. It is very similar, so I installed it and is working, but my question is would it damage the refrigerator?
Dispenser Panel locked out
If you replaced the front control board your issue may be your water tank. How long after you filled your bottle did it stop working?
Mar 01, 2014 | Maytag Refrigerators
Circuit board 3200
Have you contacted the Cuisine Art service centre if in the US try 1-800-726-0190.
Nov 21, 2013 | Cuisinart Cwc-3200 32 Bottle Wine Chiller
MY REFRIGERATOR CONSTANTLY RUNS BUT FREEZER DOES NOT FREEZE AND FRIDGE DOES NOT GET COLD. ONLY A LITTLE COLD AIR BLOWS FROM INSIDE OF FREEZER BUT NOT COLD ENOUGH. FRIDGE MOTOR JUST KEEPS RUNNING AND
Can you tell me if there is a layer of frost covering the back panel inside the back of the freezer? Here is a photo of a panel that has frost building because of a defrost problem HERE
Here is a GD5NHAXMB00Parts Manual go to page 16 and item number 6 is the 2303804 User Control and Display Board
The board could be the problem causing defrost failure or the W10135091 Electronic Control Board
Sometimes these boards will have burn marks or signs of heat damage but not always. Can you unplug the refrigerator and examine the above board first? It can be found on page 17 and item number 18 Once you have done this and see no problems we will examine the defrost heater 2323198 Defrost Heater
I am here to help you resolve this problem so please respond Thanks Sea Breeze
Mar 29, 2013 | Whirlpool GD5SHAX Side by Side...
N'finity 170 bottleis dual bottle zone wine refrigerator. Unit will begin cycle when turn off and on. Gets down to set temp and will cycle correctly maybe 2 times and then temp will slowly rise. Unit will...
Hi, there are some little thermal switches, and or 2 fans that may not be working properly. In both cases they are not cooling the unit down enough for it to maintain the set temperature. This unit is pretty much low grade, high cost, JUNK. Your minor repair might cost in the $400.00 to $500.00 range, but shortly after the evaporator (part of the cooling system) will fail. That part is not available. It took me $350.00 repair call to find this out. Good luck, and enjoy it will you can. By the WineEnthusiast only offer to help will maybe be a $150.00 price break on a new and improved model
Jan 25, 2013 | Refrigerators
Instruction manual for dihl wine cooler 32 bottles
i have a dihl 21 bottle dual control wine cooler. the temperature display keeps flashing and won't set, this is now happening with both top and bottom ... how do i fix it
May 18, 2012 | Refrigerators
The unit seems to be overheating and shuts off.
wer
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | VinoTemp 32-Bottle Wine Cellar -...
Our 18 bottle vinotemp cooler quit cooling, the electrical is ok
Sounds like the cooling unit, i.e. heat sink and controller chip. $35 + $10 shipping from vinotemp, and you install yourself. I'm looking at the same thing (on the 28TEDS), though mine came after having to replace (for $45 and my own installation, incl. soldering) the circuit board. I hope yours doesn't go, too. I've read of others. Pretty poor quality parts they appear to use. I'm trying to find somewhere to buy the controller chip on its own, as the heat sink is simply a hunk of metal. Hopefully that's do-able, as it is with computer cpu's.
See:
http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts
Dec 28, 2009 | VinoTemp VT-18TEDS 18-Bottle...
Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Mar 19, 2009 | KitchenAid Refrigerators
VinoTemp 32-Bottle Wine Cellar - Stainless-Steel Logo
12 people viewed this question
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
