Question about Epson WorkForce WF-3520 All-in-One Inkjet Printer
Epson WF-3520 - read paper feed - prints crooked
  • 68 Answers
SOURCE: EPSON STYLUS C4OUX
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Posted on Jul 15, 2008
sherlyn c
  • 134 Answers
SOURCE: I need a repair service for EPSON stylus photo
Please log on to epson.com. Click on north america, then usa. Go to the drivers and support page. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
Posted on May 04, 2009
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
SOURCE: paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
Posted on Jun 01, 2009
  • 526 Answers
SOURCE: Epson R340 does not feed paper or feeds it crooked
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
Posted on Jan 02, 2010
Epson WF-2530 Says paper out, feeds one sheet 2/3 then wont print
you might have to check for a maintenance kit and change the rolls.
Oct 21, 2016 | Epson WorkForce WF-2530
Epson WF-3529 printer seems to feed two sheets at a time when printing
In some countries, due to moisture in the air, during some weather conditions, this is common.
Fan paper well before loading in the tray.
Also depends on the type of paper.
Use manufacturer recommended grade. gsm80 in most cases.
Sep 06, 2016 | Epson WorkForce WF-3520 All-in-One Inkjet...
MY Epson WF-3520 will not print from the rear paper feed.
Try reloading the drivers for you printer for XP, un-install the windows 7 driver and install xp. check the Epson web site for xp drivers if available.
Apr 06, 2015 | Epson WorkForce Office Equipment &...
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
What is error OxF1
0xF1 means there is a paper jam. Are any of the lights on the machine flashing? Are any of them solid ? Epson WorkForce WF 3520 All in One Printer
Sep 15, 2014 | Epson WorkForce 600 All-In-One InkJet...
Epson wf-2530 printer error see your documentation
Turn the printer unit ON
2. Pull the power plug from the back side of it
3. wait 1 min
4. Plug unit back in
5. wait 3 full minutes
6. try to print does the error still exist? If yes continue below
Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away.
If you continue to experience problems, PLEASE RESPOND TO ME
Dec 16, 2013 | Epson WorkForce Office Equipment &...
Epson WorkForce WF-3520 All-in-One Inkjet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
