Question about KitchenAid Dryers
Cycle sentry setting
How is the cycle sentry setting used
Program the keyless entry
i guess you meant HOW CAN I program? (key word "I")
is car USA car?????? (our rules are UNIQUE)
the operators guide on all jeeps cover this.
posted this 100s of times here.
there are lots of rules related to this.
first off most newer cars, you need 2 keys to make a 3rd.
and has a 8 key limit,
and new key must be new, as used ones will not program.
tricky huh? and gets worse in time, the 2010 you cant do at all.
my 08 can do. and did.
see?
the car came with 2 keys, lost one?
that be first first.
lost operators guide, even look yet?
WJ jeep year 2000
ill read the book for you.
veh. theft security chapter.
chapter 8q in the FSM.
page 7 , "customer method"
ill see if i can paste it here, (found it in 10 seconds)
quote, real FSM
CUSTOMER LEARN METHOD
The Customer Learn feature is only available on
domestic vehicles, or those vehicles which have a
U.S. country code designator. This programming
method also requires access to at least two valid Sentry
Keys.
If two valid Sentry Keys are not available,
or if the vehicle does not have a U.S. country code
designator, the Secured Access Method must be used
to program new or additional valid keys to the SKIM.
The Customer Learn programming method procedures
are as follows:
(1) Obtain the blank Sentry Key(s) that are to be
programmed as valid keys for the vehicle. Cut the
blank key(s) to match the ignition switch lock cylinder
mechanical key codes.
(2) Insert one of the two valid Sentry Keys into the
ignition switch and turn the ignition switch to the
On position.
(3) After the ignition switch has been in the On
position for longer than three seconds, but no more
than fifteen seconds, cycle the ignition switch back to
the Off position. Replace the first valid Sentry Key in
the ignition switch lock cylinder with the second
valid Sentry Key and turn the ignition switch back to
the On position. The second valid Sentry Key must
be inserted in the lock cylinder within fifteen seconds
of removing the first valid key.
(4) About ten seconds after the completion of Step
3, the SKIS indicator in the instrument cluster will
start to flash and a single audible chime tone will
sound to indicate that the system has entered the
Customer Learn programming mode.
(5) Within sixty seconds of entering the Customer
Learn programming mode, turn the ignition switch to
the Off position, replace the valid Sentry Key with a
blank Sentry Key transponder, and turn the ignition
switch back to the On position.
(6) About ten seconds after the completion of Step
5, a single audible chime tone will sound and the
SKIS indicator will stop flashing, stay on solid for
three seconds, then turn off to indicate that the
blank Sentry Key has been successfully programmed.
The SKIS will immediately exit the Customer Learn
programming mode and the vehicle may now be
started using the newly programmed valid Sentry
Key.
Each of these steps must be repeated and completed
in their entirety for each additional Sentry
Key that is to be programmed. If the above steps are
not completed in the given sequence, or within the
allotted time, the SKIS will exit the Customer Learn
programming mode and the programming will be
unsuccessful. The SKIS will also automatically exit
the Customer Learn programming mode if it sees a
non-blank Sentry Key transponder when it should
see a blank, if it has already programmed eight (8)
valid Sentry Keys, or if the ignition switch is turned
to the Off position for more than about fifty seconds.
NOTE: If an attempt is made to start the vehicle
while in the Customer Learn mode (SKIS indicator
flashing), the SKIS will respond as though the vehicle
were being started with an invalid key. In other
words, the engine will stall after about two seconds
of operation. No faults will be set.
NOTE: Once a Sentry Key has been programmed as
a valid key to a vehicle, it cannot be programmed
as a valid key for use on any other vehicle.
end quote.
got all that?
if confused, ask any ASE shop in USA for help
they CAN DO !
Dec 13, 2015 | 2000 Jeep Grand Cherokee
How do I correct the battery drainage problem with my sentry 0500 safe?
please assure you use this battery set correctly at first, is there any other profiles were working but you don't know,if yes, please shut it up and recheck.
Mobile Power Mall--Celia
May 22, 2012 | Sentry Fireproof Safe
I un connected the battery to my dodge charger 06 and then reconnected it now it will not start what could be wrong with it
The Customer Learn feature is only available on domestic vehicles, or those vehicles which have a U.S. country code designator. This programming method also requires access to at least two valid Sentry Keys. If two valid Sentry Keys are not available, or if the vehicle does not have a U.S. country code designator, the Secured Access Method MUST be used to program new or additional valid keys to the SKREEM/WCM. The Customer Learn programming method procedures are as follows:
  1. Obtain the blank Sentry Key(s) that are to be programmed as valid keys for the vehicle. Cut the blank key(s) to match the ignition switch lock cylinder mechanical key codes.
  2. Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the On position.
  3. After the ignition switch has been in the On position for longer than three seconds , but no more than fifteen seconds , cycle the ignition switch back to the Off position. Replace the first valid Sentry Key in the ignition switch lock cylinder with the second valid Sentry Key and turn the ignition switch back to the On position. The second valid Sentry Key must be inserted in the lock cylinder within fifteen seconds of removing the first valid key.
  4. About ten seconds after the completion of Step 3, the security indicator in the instrument cluster will start to flash to indicate that the system has entered the Customer Learn programming mode.
  5. Within sixty seconds of entering the Customer Learn programming mode, turn the ignition switch to the Off position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the On position.
  6. About ten seconds after the completion of Step 5, the security indicator will stop flashing, stay on solid for three seconds , then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKREES/ SKIS will immediately exit the Customer Learn programming mode. After the ignition is cycled the vehicle may be started using the newly programmed valid Sentry Key.
NOTE: The Remote Keyless Entry (RKE) Transmitter will also be programmed during this procedure.
Each of these steps must be repeated and completed in their entirety for each additional Sentry Key that is to be programmed. If the above steps are not completed in the given sequence, or within the allotted time, the SKREEM/ WCM will exit the Customer Learn programming mode and the programming will be unsuccessful. The SKREEM/ WCM will also automatically exit the Customer Learn programming mode if it sees a non-blank Sentry Key transponder when it should see a blank, if it has already programmed eight (8) valid Sentry Keys, or if the ignition switch is turned to the Off position for more than about fifty seconds .
NOTE:
  • If an attempt is made to start the vehicle while in the Customer Learn mode (security indicator flashing), the SKREES/SKIS will respond as though the vehicle were being started with an invalid key. In other words, the engine will stall after about two seconds of operation. No faults will be set.
  • Once a Sentry Key has been programmed as a valid key to a vehicle, it cannot be programmed as a valid key for use on any other vehicle.
Jun 09, 2011 | 2006 Dodge Charger
Never set the safe before
If you need your lost combination, you must send in a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
May 26, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
How do I set my Sentry talking clock?
Many Sentry product manuals can be down loaded from the following URL
http://www.sentryindustries.com/support/manuals.asp
The instructions for Sentry CR104 is located at the following URL
http://www.sentryindustries.com/pdf/instructions/CR104_instructions.pdf
This may be unrelated to your problem, but
I have noticed sometimes the instructions tell you to use the ADJUST key.
If that does not work try the SET key sometimes it will work instead of the ADJUST key.
Mar 12, 2010 | Sentry CR104 Clock Radio
How can I set the timezone on my Sentry self-setting atomic clock?
Jan 09, 2010 | Sentry CR104 Clock Radio
How to program a new remote control for jeep grand cherokee 2002
Programing Sentry keys: 1. Dealer-Programming additional Sentry Keys (requires ONE original key)
In situations where only one key is available, keys must be programmed by the dealer via the Secured Access Method. The Secured Access method applies to all vehicles. This method requires the use of a DRBIIIt scan tool and will also require that you have access to the unique four-digit PIN code that was assigned to the original SKIM. The PIN code must be used to enter the Secured Access Mode in the SKIM. This PIN number may be obtained from the vehicle owner, from the original vehicle invoice, or from the DaimlerChrysler Customer Center. Refer to the appropriate diagnostic information for the proper Secured Access method programming procedures.
2. Self-Programming additional Sentry Keys (requires TWO original keys)
Detailed steps: (1) The first step of course is to acquire a blank transponder key. These can be purchased from your Jeep dealer or bought online. Online prices are usually around $20.00. You can then take the blank key along with one of your original keys to any key maker or locksmith and have it cut to match, just like with any other key.
(2) Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the On position.
(3) After the ignition switch has been in the On position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the Off position. Replace the first valid Sentry Key in the ignition switch lock cylinder with the second valid Sentry Key and turn the ignition switch back to the On position. The second valid Sentry Key must be inserted in the lock cylinder within fifteen seconds of removing the first valid key.
(4) About ten seconds after the completion of Step 3, the SKIS indicator in the instrument cluster will start to flash and a single audible chime tone will sound to indicate that the system has entered the Customer Learn programming mode.
(5) Within sixty seconds of entering the Customer Learn programming mode, turn the ignition switch to the Off position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the On position.
(6) About ten seconds after the completion of Step 5, a single audible chime tone will sound and the SKIS indicator will stop flashing, stay on solid for three seconds, then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the Customer Learn programming mode and the vehicle may now be started using the newly programmed valid Sentry Key.
Each of these steps must be repeated and completed in their entirety for each additional Sentry Key that is to be programmed. If the above steps are not completed in the given sequence, or within the allotted time, the SKIS will exit the Customer Learn programming mode and the programming will be unsuccessful. The SKIS will also automatically exit the Customer Learn programming mode if it sees a non-blank Sentry Key transponder when it should see a blank, if it has already programmed eight (8) valid Sentry Keys, or if the ignition switch is turned to the Off position for more than about fifty seconds.
NOTE: If an attempt is made to start the vehicle while in the Customer Learn mode (SKIS indicator flashing), the SKIS will respond as though the vehicle were being started with an invalid key. In other words, the engine will stall after about two seconds of operation
NOTE: Once a Sentry Key has been programmed as a valid key to a vehicle, it cannot be programmed as a valid key for use on any other vehicle.
From WJ's Forum: http://www.wjjeeps.com/sentry.htm
Hope helped (remember rated this help) Good luck.
Nov 02, 2009 | 2002 Jeep Grand Cherokee
2003 Chrysler T&C Key programming
STANDARD PROCEDURE - TRANSPONDER PROGRAMMING USING A DRB III® SCAN TOOL All Sentry Keys included with the vehicle are pre-programmed to work with the Sentry Key Immobilizer System (SKIS) when it is shipped from the factory. The Sentry Key Immobilizer Module (SKIM) can be programmed to recognize up to a total of eight Sentry Keys. When programming a blank Sentry Key transponder, the key must first be cut to match the ignition lock cylinder of the vehicle for which it will be used. The vehicle's four digit PIN code will be required to complete this task since you will need it to enter the Secured Access Mode in the SKIM. The following steps must be completed using a DRB III® scan tool:
  1. Insert the blank key into the ignition and turn it to the RUN position.
  2. Using a DRB III® scan tool, select "Theft Alarm," "SKIM," "Miscellaneous," and then "Program New Key."
  3. Enter the four digit PIN code using the DRB III® scan tool. When programming is completed, the SKIM will exit Secured Access Mode and the DRB III® scan tool will display the results of your attempt to program the key. One of five distinct results may be displayed. All five are listed below:
    • "Programming Successful" is displayed if the Sentry Key programming is successful.
    • "Learned Key in Ignition" is displayed if the key in the ignition has already been programmed into that vehicle's SKIM.
    • "Eight Keys Already Learned (At The Maximum) Programming Not Done" is displayed if eight keys have already been programmed into the SKIM. In this case, if a new key needs to be added due to a lost or defective key, the "Erase All Keys" command (which requires entering the Secured Access Mode) has to be performed. Following the "Erase All Keys" command, all keys that will be used to operate the vehicle MUST be reprogrammed to the SKIM.
    • "Programming Not Attempted" is displayed after an "Erase All Keys" function is executed.
    • "Programming Key Failed" is displayed if further diagnosis is required.
To learn additional keys, turn the ignition OFF, remove the learned key, insert the next new blank key, and repeat the steps from the beginning.
“CUSTOMER LEARN” MODE This feature is only available on domestic vehicles or those which have a U.S. country code designator. This procedure requires access to at least two valid Sentry Keys. If two valid Sentry Keys are not available, Sentry Key programming will require the use of a DRB III® scan tool.
The steps required to program Sentry Keys with two valid Sentry Keys follows:
  1. Obtain the blank Sentry Key(s) that need to be programmed. Cut the keys to match the ignition lock cylinder mechanical key codes.
  2. Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the ON position.
  3. After the ignition switch has been in the ON position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the OFF position. Replace the first valid Sentry Key in the ignition lock cylinder with the second valid Sentry Key and turn the ignition switch back to the ON position. The second valid Sentry Key must be inserted within 15 seconds of removing the first valid Sentry key.
  4. About ten seconds after the completion of Step 3, the indicator light will start to flash and a single audible chime tone will sound to indicate that the system has entered the "Customer Learn" programming mode.
  5. Within sixty seconds of entering the "Customer Learn" programming mode, turn the ignition switch to the OFF position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the ON position.
  6. About ten seconds after the completion of Step 5, a single audible chime tone will sound and the indicator light will stop flashing and stay on solid for three seconds and then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the "Customer Learn" programming mode and the vehicle may be started using the newly programmed Sentry Key.
These steps must be completed in their entirety for each additional Sentry Key to be programmed. If any of the above steps are not completed in the given sequence, or within the allotted time, the SKIS will exit the "Customer Learn" programming mode and the programming will be unsuccessful. The SKIS will also automatically exit the "Customer Learn" programming mode if:
  • It sees a non-blank Sentry Key when it should see a blank.
  • If it has already programmed eight (8) valid Sentry Keys.
  • If the ignition switch is turned to the OFF position for more than about fifty (50) seconds.
NOTE: If you attempt to start the vehicle while in “Customer Learn” mode (LED flashing), the vehicle will behave as though an invalid key is being used (i.e. the engine will stall after two (2) seconds of running). No faults will be logged.
NOTE: Once a Sentry Key has been programmed to a particular vehicle, it cannot be used on any other vehicle.
Oct 15, 2009 | 2003 Chrysler Town & Country
Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Sep 29, 2008 | Sentry Fireproof Safe
Remote keyless entry
“CUSTOMER LEARN” MODE This feature is only available on domestic vehicles or those which have a U.S. country code designator. This procedure requires access to at least two valid Sentry Keys. If two valid Sentry Keys are not available, Sentry Key programming will require the use of a scan tool.
1. Obtain the blank Sentry Key(s) that need to be programmed. Cut the keys to match the ignition lock cylinder mechanical key codes. 2. Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the ON position. 3. After the ignition switch has been in the ON position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the OFF position. Replace the first valid Sentry Key in the ignition lock cylinder with the second valid Sentry Key and turn the ignition switch back to the ON position. The second valid Sentry Key must be inserted within 15 seconds of removing the first valid Sentry key. 4. About ten seconds after the completion of Step #3 , the indicator light will start to flash and a single audible chime tone will sound to indicate that the system has entered the "Customer Learn" programming mode. 5. Within sixty seconds of entering the "Customer Learn" programming mode, turn the ignition switch to the OFF position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the ON position. 6. About ten seconds after the completion of Step #5 , a single audible chime tone will sound and the indicator light will stop flashing and stay on solid for three seconds and then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKREES will immediately exit the "Customer Learn" programming mode and the vehicle may be started using the newly programmed Sentry Key.
NOTE: The Remote Keyless Entry (RKE) Transmitter will also be programmed during this procedure. These steps must be completed in their entirety for each additional Sentry Key to be programmed. If any of the above steps are not completed in the given sequence, or within the allotted time, the SKREES will exit the "Customer Learn" programming mode and the programming will be unsuccessful. The SKREES will also automatically exit the "Customer Learn" programming mode if:
  1. It sees a non-blank Sentry Key when it should see a blank.
  2. If it has already programmed four (4) valid Sentry Keys.
  3. If the ignition switch is turned to the OFF position for more than about fifty (50) seconds.
Jul 16, 2008 | 2007 Dodge Caravan SXT Minivan New Cars
Open Questions:
Dryers Logo
35 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
