Question about Synrgy Mens Big & Tall Deep Navy Mixed Media Polo Mens
Watch stops, I reset it and shake it and it works for awhile
My watch will work for a while. Sometimes it stops and I will reset it. I have to shake it to get it going. Sometimes it works for days and sometimes it quits in a couple of hours
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
2004 F150 brakes
take out the air from the system, the break pump is unable to retract the breaking fluid if there's air in it
Mar 13, 2010 | 2004 Ford F150
Battery is good, but watch stopped.
You need to hold in reset and mode to make it go back on.
Dec 31, 2009 | Novelty Watches
The Miele S251i just stopped working. Is there an
How long has unit been down? There is a inline fuse by motor housing internally in unit, but sometimes these units take awhile for them to reset
Dec 03, 2009 | Miele S251i Plus Bagged Canister Vacuum
Works fine when under the light but stops when I wear it.
Your capacitor will needs to be replaced. This usually has to be done about every 5-8 years.
Sep 18, 2009 | Silhouette Citizen Eco-Drive Watch
Tag automatic watch = stopped working
Stop shaking it!
You could try wearing it and it should wind itself with your body motion or...
your could manually wind it (setting 1)
Jan 22, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Jan 10, 2009 | Rado Diastar Anatom Jubile watch
Tag heuer link automatic
exact same problem, no one seems to know
Oct 26, 2008 | Tag Heuer Link Automatic Chronometer...
Synrgy Mens Big & Tall Deep Navy Mixed Media Polo Mens Logo
269 people viewed this question
Top Synrgy Clothing Experts
treeeee
treeeee
shuyumeng
shuyumeng
Erin Wood
Erin Wood
Are you a Synrgy Clothing Expert? Answer questions, earn points and help others
