Question about Samsung SAM4s ER-650 Cash Register
Register occasionaly locks up and looses programming. have to do a complete memory reset. battery voltage good.
Has only happened twice as far as having to reload program. checked circuit board for debris, and checked connections.
I have a Royal 1100ML register and I forgot the manager passcode to finish setting it up. How can I reset this?
The only way I have found to reset this register was to pull the battery's and start all over again like it was new. if you did not back up the register then any inputs or plu's will be erased. Don't know any other way. had to reset mine twice now and put a few hours into re-programming the plu's. back-up made it easier to load last configuration. connects to a serial port on a computer and run the software that came with the register. Also since mine continues to mess up with a managers password and locks my machine I no longer use a password protect mode no do I lock out x and z reports. Think this model has a glitch since I have seen more than 1 person with the same problem and no real cure. lots of luck
Mar 12, 2017 | Retail Supplies
After power surge on sharp XE-A207 cash register the unit will not turn on or display anything on screen. Unit does have power to it
Did you have good batteries in it? If they were low, locking up is a common symptom when the machine tries to rely on them to support memory during power cuts. You might need to try a master reset and re-program it
Feb 25, 2016 | Retail Supplies
My Janome 11000 freezes up
you said it has been in the shop twice do you think that may be they did not check the circuit board out I think it might be in the timing or the board
Feb 07, 2015 | Janome 11000 Memory Craft Special Edition...
The fuse keeps blowing inside the edenpure heater
Generally speaking, fuses blow when too much current passes through them. Typically this happens when there is a short circuit some place. a connector or bare spot in a wire touching ground, a bad component on a circuit board, a bit of conductive debris on a circuit board all can cause shorts. If the fuse blows, it's doing its job to protect you from a problem you have yet to find.
Dec 01, 2013 | EDENPURE USA1000 Infrared Heater
Any four digit code works no matter how many times you reset code. how do you erase all codes and start fresh?
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
pb1000programbutton
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
I'd recommend replacing the batteries if you haven't done so yet.
Good luck--and please provide feedback if this helps!
Aug 21, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How do I change the code on a Kwikset key pad
Here you go....
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
pb1000programbutton
Aug 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Change combination, lost book
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
Here is a link to the complete instructions:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Jul 25, 2011 | Weiser Lock Powerbolt 1000 Lock
Hello I have a casio tk-1300 cash register. But he gives to E03. can anyone help me with it. I like to hear. Jarno
This means initialisation has not completed. The machine is trying to complete a memory clear. It is commonly caused by a faulty memory battery. It will also happen if the machine has been turned off long enough to flatten the battery. Work through the initialisation procedure in the programming manual. If you need the manual, it is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_and_CE-4200_and_CE-4250_programming_manual.html
Jan 27, 2011 | Casio Parts Cash Register PC Desktop
I have a Samsung Ductless Air Conditioner. It wil...
i think there is a short circuit in the fan or compressor even in the board.loop check it & say how many amper is there?
May 21, 2010 | Samsung AS18A6RB Air Conditioner
My TEC MA-1650 won't accept barcodes or PLU's nor can I delete any. Has been stored for 12 months.Cannot perform a PLU reset. Won't recognise PLU's or barcodes which should be stored in memory.Thanks
These units have memory protection battery, when power is turned off
the battery will take over, after 6 months, specially older registers, they will loose all the program info, you will need to reset the memory to factory default and then leave it plugged in a couple of days then unplug and leave a day when you power on the next day it should work if it doesn't you need to replace the battery
Nov 19, 2009 | Office Equipment & Supplies
Samsung SAM4s ER-650 Cash Register Logo
Top Samsung Retail Supplies Experts
Patrick Tinashe...
james laughton
james laughton
ray gallant
Are you a Samsung Retail Supply Expert? Answer questions, earn points and help others
