Question about Amana Refrigerators
Need evaporator fan motor Amana part # PS2167213 /no longer availible
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
catriver
  • 878 Answers
SOURCE: Amana Refrigerator SCD22JL
Good trouble shooting TD, the evap fan runs through the defrost T-stat. Change it out and you should be set. Catriver.
Posted on Aug 15, 2007
22yooper
  • 828 Answers
SOURCE: Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Posted on Jun 29, 2008
carputers
  • 255 Answers
SOURCE: My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Posted on Sep 24, 2009
Why amana fridge ABB1924WES freezer works refridgerator doesn't?
Check for a failed evaporator (cooling coil) fan motor or iced up evaporator due to a failure in the defrost timer, thermostat, or heater.
Jul 26, 2014 | Amana ABB1924WES 19 bottom mount...
I have a Amana ssd21sl, the evaporator coil freezes up, The fan motor above does not come on, but have 115v to it, Is fan motor bad.
You really need to measure the Ohms resistance for the motor.
OL means the motor is dead
0.000 means the motor is short circuited and is dead
160 to 300 ohms the motor is good
Mar 24, 2011 | Amana Refrigerators
Amana Bottom Freezer, Neither freezer nor refrigerator is cooling
Contact the repairclinic.com for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Apr 20, 2017 | Amana ARB1917CSR Bottom Freezer...
Frig is no longer cold, fan is not turning
It is no longer cooling because the fan is not turning and the evaporator coil is freezing up. The fan has to be replace or fixed
Nov 26, 2009 | Amana ABB1927DE Bottom Freezer...
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling no p0wer to evaporating fan
Part number R0161089 defrost thermostat $35 ,but if the freezer coil is defrosted there would be no power to the motor because this switch has to be chilled to about 0°F to send the power to the fan motor.
Sep 27, 2009 | Amana SXD524VW Side by Side Refrigerator
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana refrigarator
Hi. The most common failure for this make refrigerator is a bad evaporator fan motor. You should feel air coming out of the diffuser in your freezer. If not, either the fan motor is bad or you have alot of frost build up on the evaporator. You would see alot of frost on the back wall of the freezer where the evaporator coil is located. If this is the case, most likely the defrost bimetal thermostat. But if no frost, the evaporator fan motor is most common and likely to be your problem. Also check and make sure your compressor is running. Compressor failure is common on this make refrigerator. Visit me on Ebay username: themackshack. Good luck! Mack
Dec 15, 2007 | Amana ABB1921DE Bottom Freezer...
Refridgerator and freezer is no longer cold
evaporator freezer fan motor has low voltage. Amana M # SCD22NW S # 9403120669. Could use some help. Thanks
Oct 23, 2007 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
