Question about Sanyo Televison & Video
SANYO DP46848 no picture turns on for 1 second then off
Turns on green light then screen lights up blue for 1 second that's it !
  • saenzofquali
    saenzofquali Feb 13, 2014
    nothing looks or smells burned on curcuit boards
4 Suggested Answers
  • 71 Answers
SOURCE: sanyo 42" flat screen tv green light comes on but no picture
oops u r in trouble.
Posted on Mar 05, 2009
  • 135 Answers
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Posted on Aug 23, 2009
budmrtn
  • 11361 Answers
SOURCE: my flat screen sanyo tv screen wont turn on. the
Try disconnecting the connector KBL on the main board as shown in my picture #DSCF0585 to see if the backlights will come on, if it does, the main board is bad.
Also check the voltages on the output connectors of the power supply.
http://s807.photobucket.com/albums/yy352/budm/SANYO%20TV%20DP26649/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 24, 2010
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
No picture there used to be lines at the top
It sounds that there is some loose contacts with any cable connectors, or to any solder terminals at the circuit board. It will be best to contact any service technician, or the authorized service center for Sanyo. Gopakumar Gopalan Google
Feb 24, 2014 | Sanyo DP46848 LCD TV
Sanyo DP46848 im stumped lol... with nothing connected ( aka ) cable and or any other components .. just plug and turn on .. the screen has a solid blue bar from top to bottom with small white lines in...
Although you have not posted a picture, I believe you may have a screen or LCD panel problem, the panels have film connections that go from the t-con module, through the panel control pc boards then through thinn film connectors from the lcd screen. Likely this is the problem.
Oct 29, 2013 | Sanyo DP46848 LCD TV
Sanyo DP46819 green ind. light comes on but no screen or audio
Not true that its def the power. Mine did the same thing. Green light, no sound or video. Replaced the power board with same results. Waiting on main board now.
Jun 07, 2012 | Sanyo DP46848 LCD TV
Sanyo DP46848 has sound but no picture.
Tv turn now,have a flashes of picture a few sec.than dies have sound left only?Yes,than ur tv have a 2 long boards are dead that call LCD inverter boards.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 07, 2010 | Sanyo DP46848 LCD TV
I have the sanyo dp46848 it 3 months past warranty , we had a thunderstorm ,my wife turned off the tv but we did not unplug it. when the storm was over we turned it on and all we got was a led power light...
It can be the main logic board EPROM is scrambled since the TV was plugged during the thunder storm, and /or the power supply module are damaged.
You will have to do more in-depth troubleshooting.
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
Jul 21, 2010 | Sanyo DP46848 LCD TV
Lamp replace light is still one even though i replaced the bulb
I'm having this same problem. The Ready light is on Green and the LAMP light is on Red. Replace Lamp light is also on. The device turns on, displays the blue SANYO boot screen for a few seconds, then shuts off.
Jul 14, 2010 | Sanyo PLC XP41 Multimedia Projector
I have a SANYO DP46848, after i turn on the TV after a few minutes the picture turns a blue/grey color. There is still a picture and sound, but poor picture quaility. Need some help?
The ic on the T-con board is failing you could confirm this by spraying circuit cooler on the ic . The T-con board is located in the middle top on the unit has a cable from the mainboard to the t-Con
and two other going from it to the panel
You can try either Shopjimmy.com or TopsElectronics in Haverhill Ma
Dec 07, 2009 | Sanyo DP46848 LCD TV
Televison & Video Logo
55 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
