Question about Kodak Esp 5210 All-in-one Inkjet Printer
Control panel seems locked out
My esp5210 links wirelessly to my network and prints fine. My aio software works allowing me to scan etc. the problem is I can't do anything from the control panel on the printer itself. I can move the cursor thru the options, switch it off/on but it won't copy, scan or go into network settings.
  • 2976 Answers
SOURCE: Can't load the Kodak AiO Homecenter software
Go to the control panel and uninstall it. Don't just delete the program from windows explorer. Reinstall everything. It SHOULD work fine.
Posted on Jan 01, 2009
  • 285 Answers
SOURCE: my KODAK 5300 AiO printer wont print from PC
try pressing the copy and cancel buttons at once a blank sheet of paper will come out and that should solve your problem. I hope this helps
Posted on Jan 28, 2009
  • 107 Answers
SOURCE: Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Posted on Apr 20, 2009
Mykel_N
  • 315 Answers
SOURCE: Kodak AiO software
Hiya,
Here is the link to the Kodak clear utility tool for removing their software:
http://wwwuk.kodak.com/global/en/service/downloads/private/xp_vista_98_ClearUtility.jhtml?pq-path=12361
Select what software you need to remove from the drop down list, click continue and follow the instructions from there.
I hope this helps.
Mike
Posted on Jun 17, 2009
  • 60 Answers
SOURCE: Battling between KODAK AIO 7 vs Dell wireless laptop.
try this
  1. Open the Printers folder:
  2. XP Operating System: Select Start > Settings > Printers and Faxes.
  • VISTA Operating System: Select Start > Control Panel > Printers.
  1. Delete all ESP 7 and ESP 9 printers from the folder. The printers are listed as "KodakESP7+xxxx" or "KodakESP9+xxxx", where xxxx can be any number.
  2. Close the Printers folder.
  3. Press Ctrl + Alt + Delete on your computer keyboard, then select Task Manager.
  4. Select the Processes tab.
  5. Stop each of the following processes. For each process, click the process, then click End Process.
  6. AiOHomeCenter.exe
  • EasyShare.exe
  • EKDiscovery.exe
  • EKIJ5000MUI.exe
  • KodakSvc.exe
  • mDNSResponder.exe
  1. Power cycle the printer. (Press the power button to turn off the printer. Wait approximately 30 seconds, then press the power button to turn on the printer.)
  2. Open the home center software.
  3. Click Install Kodak Printer in the bottom right corner of the home center to add your all-in-one printer to your computer.
let me know if this worked or not.......
Posted on Jul 08, 2009
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
HP officejet 6500A plus wireless printer seems to work fine for printing over the network but scanning seems to disconnect part way through a scan. Im using Windows 7 with Norton Security Suite on all...
You need to choose compatible driver in Windows 7. First, you have to click the 'Start' button and select and 'All Programs'. Then, go to 'Accessories' and select 'System Tools' and then click 'System Information'. Then, you have to select the 'System Summary' and then review the OS Name and System type to find out which version of operating system you are running. Then, accordingly choose the network printer driver for your computer.
Jan 03, 2011 | HP Officejet 6500 Wireless All-in-One...
I get an error message when I scan. It says Error
ISSUE: The error Waiting for PC is displayed on the control panel when scanning, using the Start Scanbutton on the control panel. The user will also notice a Not Setup on PC error when pressing theScan to … button. Note that scan from the PC works properly without an error. SOLUTION: The probable causes for this issue are listed below:
  • Firewall denying access to PC
  • Device polling not enabled
  • The scan to function is not enabled in the HP Toolbox
  • The destination has not been added to the Scan to button from HP toolbox
  • The HP Toolbox is losing the scan to destination
How to troubleshoot this issue:
  1. PC protection software such as firewall software may prohibit proper communication between HP AiO products and Toolbox and scanning software. Firewalls may need to be reconfigured to allow Toolbox to communicate with the AiO. The Toolbox software is similar to Microsoft Outlook and Internet Explorer in this way. Temporarily disabling firewall software may be helpful in determining if it needs to be reconfigured for Toolbox to operate properly. Please contact your third party firewall software vendor if assistance is needed to reconfigure the firewall. The following third party support Web sites may be useful:
  2. When Device Polling is turned off, the Alerts and the Scan to e-mail or folder options in the HP Toolbox are disabled, and the START SCAN function on the HP LaserJet AiO product control panel is also turned off. CLICK HERE for instructions on how to turn on Device polling.
  3. To program the device SCAN TO ... button, view the device settings. Open the HP Toolbox and click the Scan to tab. For more information, CLICK HERE to view the document titled HP Color LaserJet 2840 AiO Series Products - How to use "Scan To E-mail" or "Scan to Folder" from the Device
  4. The User loses the folder when choosing to save scanned files under the Scan to Folderoption of the Scan to Tab. The User also may lose the email settings under the Scan to Emailoption of the Scan to Tab. The User restarts the toolbox and it works for some time and the problem repeats again. Perform the following in the order listed to resolve this issue:
    1. Run the Fix Scan Utility and see if it resolves the problem. Click here for the Fix Scan Utility at http://www.hp.com If not, proceed to the next step.
    2. Check the firmware version and make sure that it is up to date. print a configuration page to see what the current firmware version is. Compare it to the latest version offered on HP.com Click here for HP.com at http://www.hp.com . If it is not the latest version then upgrade it to the latest version available on the web.
    3. Download the Software Update Version 3.0 from HP.com and install it. Click here to download the software update from http://www.hp.com
  5. For Toolbox Reset Persistent Data issues, CLICK HERE to view the document titled HP Color LaserJet 2800 All-in-One series - Toolbox Reset Persistent Data
  6. If the issue persists, uninstall and reinstall the printer software. CLICK HERE to view the document titled HP LaserJet 2820 and 2840 AiO Series Products - Uninstalling or Removing the Printing Software and Shared Components
Apr 07, 2010 | HP LaserJet 3015 All-In-One Printer
Won't scan
We need to first check the driver to make sure it is installed and working correctly. Please go to “start menuè control panelè scanners and cameras”.
(Note: For Vista users, you must select “classic view” in control panel to be able to see “scanners and cameras”)
You should now see all scanners currently installed.
If you do see your brother scanner, please right click the icon and select “properties”; here you can select “test scanner”.
If the test fails, select the “network settings” tab. Here you can have the driver set to locate the device by name or by IP address, please select IP address and make sure the IP address matches that of your brother machine.
To get the IP address on your brother, print out the network settings page; either with the “report” button on the printer or go “menuè print reports”
If the scanner does not appear in the list at all, you will need to reinstall the software. You can download the software using the below link.
http://welcome.solutions.brother.com/bsc/Public/CountryTop.aspx?reg=us&c=ca&lang=en
If your scanner successfully completed the diagnostic test, we can move on to try using control center to scan.
To access Control Center, please go to “Start menuè All programsè brotherèControl Center”.
In Control center, please make sure the correct device is being selected in the ”model” drop down list.
Thanks,
Pat
Mar 26, 2010 | Brother MFC 7840W Printer
HP LaserJet 3055 scan over network. How does one set the Laserjet 3055 up to scan over the network? I'm running XP professional.I set the printer up through Control panel - printer and faxes - Add a...
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
Jun 29, 2009 | HP LaserJet 3055 All-In-One Printer
try this
  • EasyShare.exe
  • EKDiscovery.exe
  • EKIJ5000MUI.exe
  • KodakSvc.exe
  • mDNSResponder.exe
May 15, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
HP PRINTER PHOTOSMART C4180 on WINDOWS VISTA
Although the original poster mentioned networking he/sredm.gifhe also seemed to be asking about HP all-in-one issues in general and Vista compatibility. Networking, scanning, copying and printing can have seperate and integrated issues to varying degrees. This may not just be a scanner networking general query.
In my case I downloaded and installed the additional bundled software per HP's advice while trying to get the scanner to scan at the dpi level advertized for the unit. Neither Vista or HP had drivers that worked unless I installed the package. Low resolution scanning worked fine as well as the copying and printinting features. I rarely need such high scanning options but it should have worked as advertized since it was sold by an HP distributor as Vista compatible.
The downloaded AIO did allow higher resolution when scanning but caused other NON-NETWORKING issues. My computer is not networked. There is also the issue of the scan button on the printer not working with Vista. It does work with pre-Vista. Again not a network issue but a driver issue with Vista.
Taken from the MHTML file from the unit software found after the purchase......
HP Printers - The Scan Button on the Printer Does Not Work Correctly When the Printer is Connected to a Windows Vista Computer
Issue
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly.
Solution
Scan documents using Windows Fax and Scanning or Paint.
Cause
The drivers in the Windows Vista operating system do not support button press functionality on the printer. END EXERPT.
Button functionality. DPI resolution. There are driver issues with some of the HP units and Vista. Not just networking issues.
In my opinion these issues should have been fully disclosed prior to purchase or functional Vista drivers should be an option. Therefore I offer the warning that Vista may have issues with this and other software and hardware.
I only speak of non-networking issues but either way a unit should work as advertized or sold. My comments are based on my personal experience with one unit in this particular situation. After all Vista is fairly new to most of us.
Sep 18, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Wireless
I had the same problem. It is now working.
The problem was a bad conecction of the network interface card.
I simply pluged it out and inserted it in and it is now working fine !!
Hope it works for you.
Dec 18, 2007 | Lexmark X9350 All-In-One InkJet Printer
Kodak Esp 5210 All-in-one Inkjet Printer Logo
13 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
