Question about NEC PCI to USB Enhanced Host Controller uPD720101
NEC uPD720101 chip - NEC PCI to USB Enhanced Host Controller uPD720101
Lamp hour reset NEC MT1060
The NEC MT1060 lamp hours is stored in an EEPROM chip built into the lamp. As soon as you put in a new lamp (MT60LP or MT60LPS), the hours will be reset. If you remove and put back in an old lamp, the unit will see the hours on that lamp. Thus if the lamp has reached 2100 hours, the projector will remain in standby. See page 53 of the manual for the replacement and reset information.
Most of the manuals for the NEC projectors are available here: http://www.nec-display.com/dl/en/pj_manual/lineup.html . The direct link to the manual for the MT1060 is http://www.nec-display.com/dl/en/pj_manual/mt1065.html .
I hope this helps.
May 24, 2016 | NEC MT1060 Multimedia Projector
NEC VersaPRO no Sound
I would uninstall the driver, in case it is corrupt and reinstall it.
Feb 03, 2014 | Computers & Internet
How to replace NEC NP 07 Lp projector lamp
lamp USD70
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 10, 2013 | NEC NP07LP Projector Lamp
We use NEC MT1065 and just replace its lamp but it still won't switched on (lamp indicator led is red). How can I reset it ?
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, if your old lamp has only had the reflector replaced then it will make no differance because the chip tells the projector weather or not to power up depending on the hours its counted, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention, just as an added note, a solid red lamp indicator light means that the lamp has expired, if its flashing red this means its nearing the end of its life, if the status indicator light is flashing then there could be another issue, by counting the flashes you can reffer to the manual in the troubleshooting section to diagnose the fault, I know this is very late, but anyone else reading this may find it helpfull.
Nov 29, 2010 | NEC MultiSync MT1065 Multimedia Projector
Nec mt-1065 lamp hours reset
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention.
Oct 25, 2010 | NEC MultiSync MT1065 Multimedia Projector
Cant find drivers for NEC Lavie G
lookup the specs for the machine and then download the drivers for the different hardware that make it up... you maybe looking for a video driver for nec lavie s ls 900/8e when you should be looking for the driver for the actual graphics chip family inside of it... thats worst case... best case goto the nec site and download the drivers...
Dec 21, 2009 | NEC LaVie S LS900/8E Notebook
Would you be able to help me to program the directory button on our NEC Elite phone system so we could scroll back through caller ID for the last 50 calls?
You can pull the card out hot. The KMM chip is IC6 toward the connector at the back of the card. The other requirement, if you have the KMM chip, is that Caller ID be enabled for your MIFM card. It is done through system programming. You can turn it on by these key sequences. Follow this EXACTLY from a display phone (start idle): <Feature>, #0*8974, press <Line 7> button, press <Line 3> button, press *, 4,01, <Transfer><Speaker>. Test again. One other item, MIFM firmware 5.0 is required for 50 call storage. If firmware level is lower, you will only get 10 call storage. If all the above fails, you will need to call a certified NEC technician to check it out.
Dec 31, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC video card driver not be found
If you're using windows XP try using windows update to find the driver for you. Also try contacting their support at http://www.necam.com/contact/contact.cfm?Page=ContactUs
good luck
Jul 13, 2008 | NEC /Nogatech PCMCIA Digital Video Card...
NEC LR700/E DRIVERS
hi, i whant to be driver of NEC Lavia 750/8 laptop
Dec 26, 2007 | NEC LaVie RX Notebook
Computers & Internet Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
