Question about Baby Lock Esante
THREAD SPITS, AND THEN BREAKS
While embroidering the thread will fray, spit and then break.
    New Friend:
  • 185 Answers
Use a needle 1 size larger, fraying and splitting usually caused by the needle.
Posted on Dec 03, 2014
  • 4 Answers
SOURCE: thread breaka
First, make sure that you are threading the machine properly check your manual for right thread path.
Secondly, make sure you are using an embroidery needle.
Posted on Jan 12, 2008
  • 4 Answers
SOURCE: Baby Lock Ellure
I HAVE HAD THIS HAPPEN SEVERAL TIMES AND WHEN I WOULD CHECK THREAD IT WOULD BE OK, MOST OF THE TIME HOWEVER, IF I COMPLETELY UNTHREAD IT AND RETHREAD IT THE PROBLEM IS SOLVED. I HATE IT WHEN THEY DO THIS MUST BE A PROBLEM WITH ALL OF THEM
Posted on Aug 12, 2008
SOURCE: BabyLock Proline upper looper thread keeps breaking
I ended up switching the spools of thread around. Apparently, even though I had purchased good quality threads, one of the spools was wound in a way that made the thread loop and twist around. So I put the offending spool of thread through one of the needles and put the needle thread on the upper looper. That seems to be working. By the way, BabyLoc was very unhelpful dealing with this problem.  Thank you!
Posted on Sep 09, 2008
  • 3 Answers
SOURCE: Babylock Ellure thread issues
I have the same machine and love it. Sometimes if the thread is old that will happen to me.  And also I spray the thread with static guard before i thread the machine in dry cold weather.  Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool.  I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it.  I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
Posted on Mar 07, 2009
  • 46 Answers
SOURCE: Top thread keeps breaking on ESe2.
Many things can inter fear with the thread and cause it to break. A common problem is the thread getting wrapped around the top tension rollers on that machine. You can take off the "face cover" (side cover on the left) and look from the side and see if the 2 little rollers have thread wrapped around or underneath them. Start there.
Posted on Jul 25, 2009
Thread keeps breaking
increase the needle thread tension up more
May 11, 2018 | Sewing Machines
The top threat keep on breaking
Possible causes:
  • Needle eye too small for thread used - then thread frays and breaks
  • Cheap thread used that easily frays - esp. when thread has unequal thickness
  • Needle eye too sharp
  • Component of the thread guide is not smoothly guiding the thread or is sharp
  • Upper thread tension (far) too large
Jan 18, 2018 | Sewing Machines
How do I stop the machine breaking the top thread when I'm sewing?
There is either an error in the way it is threaded or the tension is set to high.
Nov 21, 2017 | Sewing Machines
The top needle thread gets mangled,only way to fix is to pull all thread out and rethread the needle
Sounds like the thread is shredding and fraying. Make sure the needle is the correct size for the thread. Try a brand new needle. The other possibility is a possible burr or snag somewhere in the threadpath that is catching and fraying the thread. Another possibility is the fabric is coarse and rough and acts like sandpaper on the thread. AVOID old or bargain bin threads.
All About Needles
Causes of Thread Shredding
http://www.chholderby.com/tips-tricks-and-help/part-3-thread-breaks
Sewing Machine Problems Threading breaking
Oct 09, 2017 | Sewing Machines
My brother pc700 the thread is fraying and some times it breaks
Make sure thread tails are at least 6" long when you put underneath your presser foot. Also, make sure you turn hand wheel toward you until metal take- up lever raises to highest position. Make sure needle inserted ALL THE WAY UP in needle bar goove and secure needle clamp. I M P O R T A N T: presser foot must be raised all the way UP before threading machine and pull thread TAUT when threading machine so thread can locate into the tension slots correctly. Thread still breaks? Please clean bobbin case and feed dogs for fuzz balls, lint, and anyoose broken threads! Hope this helps! If so, please give me rating for my free service. Happy sewing! Jimmy
Apr 06, 2012 | Sewing Machines
When embroidering on my Duetta 4500D, thread frays and breaks.
Try another brand of thread - I have a problem with C&C and Sulky black fraying and use Maderia.
This may also happen with other dark colors that have gone through a longer dying process that tends to weaken the thread.
Thread companies have different dying procedures.
Also, check the thread spool for nicks that may be catching the thread and if it is turn the spool so the thread feeds from the opposite end of the spool.
Feb 20, 2010 | Brother Sewing Machines
Thread frays and breaks when sewing and embroidering.
Make sure that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Aug 03, 2009 | Janome Memory Craft 9000 Computerized...
Thread breaks when embroidering
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Jan 04, 2009 | Husqvarna Designer I
Brother Embroidery machine thread keeps breaking
It doesn't matter so much the thickness of the stabilizer but more a matter of it being taut like a drum and the proper stabilizer for the fabric you're using. Couple of reasons the thread breaks...the thread gets caught on the edge of the spool in the crack where the thread originally starts, you're not using the right size spool cap or the upper thread is wrapping around the spool pin. When I use my 170 for embroidering I always use the vertical spool pin to eliminate this problem. Try it and let me know how you make out.
Nov 18, 2008 | Bernina Artista 180
Sewing Machines Logo
94 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
