Question about Ricoh SP C430DN Laser Printer
Vertical Black Lines on Page
We have had this printer approximately six months (Aug '13). This morning we started seeing faint vertical black lines all over the page. Anything I can do to fix this myself before I call a printer repairman?
  • 4 Answers
SOURCE: Faint Black Lines
Did you re-fill the black toner cartridge with genuine Ricoh toner or from somewhere else? It might be the wrong granularity.
Posted on Feb 09, 2008
  • 4 Answers
SOURCE: black streaks
Marktron
  • 7 Answers
SOURCE: vetical lines printing on page
print a coulr sample page from internal memory and if issue is present it is a physical issue with the colour pcu, if it doesnt happen on sample page, then check driver versions- update
Posted on Feb 15, 2008
  • 3 Answers
SOURCE: Black vertical lines on printed pages
check the "photoconductor unit" (pg 37 in the Maintance manual)
ours was doing it with the magenta and saw a faint 'scratch' on the roller. will attempt to replace and report back if this fixes it.
Posted on Sep 19, 2008
SOURCE: white vertical lines on printed page
change the k black drum... its the only solution trust me
thanks
Posted on Mar 09, 2009
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Faint vertical lines on my samsung lcd 1080
hi
this is the problem caused by 3 main issues
1.colour wheel
2.cathode ray tube
3.jungle ic on D-board
check it..//thank u
please rate it
Jul 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Black vertical lines on lcd screen
Has Bad LCD Panel hope its under warranty.
Apr 15, 2009 | Televison & Video
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Aug 25, 2008 | HP LaserJet 1020 Printer
Replaced printer drum but still printing with vertical lines
Hi dermtex,
since the faint lines are vertical, I think there is some thing distored the laser beam, try clean the lenses of the laser unit by clean soft cloth.
hope this helpful for you,
thanks
Hamedo
Aug 18, 2008 | Brother HL-2070N Laser Printer
Apr 09, 2008 | Ricoh CL4000DN Laser Printer
Faint Black Lines
Hi best way to check is to remove the black photoconductor and you should be able to see the little lines on it also check the the black dev/toner unit for the lines. most likely to be the black photoconductor unit though.
Thanks J
Jan 24, 2008 | Ricoh Aficio CL3500N Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Ricoh SP C430DN Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
