Question about Optics
Mendoza rm377 trigger assembly diaphram
The pellet gun will not **** to shoot and idk how the trigger spring goes back in
  • 1383 Answers
SOURCE: Trigger problems
I have repaird hundreds of nail guns with a problem similar to yours. Depending on the brand and model, the problem can be repaired by checking the following. Headvalve orings should be checked for wear and any surface that the orings contact must be smooth and free from scratches. If the surfaces are scratched try to smooth with fine sandpaper and use light grease instead of oil when assembling. The safety contact foot may not be reaching high enough into the trigger to properly push in the trigger button. Check for worn spots on the trigger that may be filled in with epoxy, loose fitting trigger caused by worn roll pin or retaining pin. Some of the trigger valves as used on many bostitch nailers (tva6 valve) used a plastic pin which contacts the trigger. If this pin is loose or worn the valve should be replaced. Some tva6 valves have a vinyl looking sort of oring that fits too loose on the spool. This vinyl oring in not available by itself but if the oring fits too loose the gun will not fire and leak air. On bostitch remove the trigger and the rollpins holding the trigger valve and apply air to gun to eject valve. (use heavy glove to catch valve as it will come out with force)
Posted on Nov 25, 2008
  • 117 Answers
SOURCE: zeroing problem
Make sure you rest the air rifle on something soft, like a folded jacket for a rolled up towel.The rifle will always shoot away from a hard surface.If you rest against the side of a tree, it will shoot away from the tree.If you leave your pellets in the sun, and they are warmer than the barrel, they will always shoot high.Good Luck
Posted on Mar 25, 2009
slohry
  • 87 Answers
SOURCE: husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Posted on Apr 10, 2009
SOURCE: nerf gun wont shoot
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Posted on Sep 17, 2009
  • 44 Answers
SOURCE: very low power and inaccurate. I think I may be
The seals are prone to drying out.. try a few drops of light oil at the point in question. If that doesn't help build the pressure, you'll have to take it in and have it serviced.
Mark the Gunsmith
*Please give feedback on this answer*
Posted on Dec 30, 2009
Crossman repair
I have a crossman pulse r78 and it will not shoot ,when you pull trigger it Gus windes oner spring do not egage
Dec 05, 2013 | Crosman Model 760 Pumpmaster Air Rifle
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Stanley tr-70 spring has no tension
It sounded good but made no sense. How do you remove the trigger/ squeeze handle assembly? This thing (Stanley TR70) is riveted together. The only piece that is removable is the staple feed tray.
Mar 01, 2012 | Tools & Hardware - Others
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
Crosman 766 was shooting fine, the next shot did not shoot the pellet and just made a funny sound. Now when you pull the bolt back and forth there is no sound to indicate a shot fired when the trigger is...
Upon cocking your gun is there the same tension with the cocking spring as there was befor? Also check the condition of your barrel seal for tears or cracks in it.
Nov 23, 2010 | Crosman Optics
Assembly instructions for reassembly. I had to disassemble glue to clean and the spring popped out and I am not sure how it goes back together
the spring goes behind the trigger, but i would need to know the brand and model glue gun to really help with this problem
Nov 17, 2010 | Crafts & Hobbies
Big Buck Hunter Pro Arcade game - gun no longer shoots.
just curious if you still have that broken gun? I am a sculptor in MN and making a piece that i wanted to put a lazor into a broken big buck hunter gun to shoot up at a sensor on a deer which would make it wink at you. thats the plan atleast trying to find a gun. thanks kari
Nov 25, 2009 | Arcade Raw Thrills Big Buck Hunter Pro...
Optics Logo
59 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
