Question about Soft Heat Micro-Plush Low Voltage Heated Mattress Pad
Soft heat matress pads
One side stopped working and only stays on 7seconds
Pad keeps ripping in center when i wash it
most likely its the size of washing machine making it rip , something this large should be washed in a large commercial washer ,its too small a diameter in the drum to bend a large sheet around without pulling it (ripping ) on a home size washer
Feb 10, 2016 | Perfect Fit White Magic Loft Mattress Pad...
Brakes vibrate the more they heat up, down hill with 5th wheel attached. I have change rotors and pads with no change, any ideas?
Sound like you over heated the the rotors and now there are worpped ..
You need to replace at least all parts in the fronts rotors pads and the calipers do the whole thing .
These parts are so cheap now a days their made in china . WE ARE TALKING 50 DOLLARS A SIDE FOR PARTS
Mar 19, 2015 | 2008 Chevrolet Silverado 2500HD 2WD
Controller on a heated matress pad shows a backward 3 does not warm up
that heated mattress pad needs to be safety tested by an electrician
faulty thermostat or internal heating wires
or the actual controller
Mar 02, 2014 | Furniture
My dog just chewed up the cord to my heated mattress pad. Where can I find a replacement without having to buy a whole new matress pad?
I could suggest that you replace the cord which can be done BUT for something that you sleep on that plugs into a wall socket I would strongly suggest you buy a new one. If you replace the cord and make a mistake you will not be around to wish you had bought a new one but you family and friends will.
May 08, 2011 | Sunbeam SG7621SP Grill
My sunbeam matress heated pad only flashes F1 and will not turn to low or high.
you either have a power issue or the pad will not go to higher levels because of a heating element issue within the pad its best to replace because if it continues or gets worse then you could be looking at a future fire or electric shock please be carefull and take the safe way and replace it!
Dec 27, 2009 | Computers & Internet
Have heating pad model 818-7. blinking red light for high when connected- but no heat. what to do. I love this soft, terry cloth hour glass heating pad controller model number: SW204. e12107 is also on...
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
Dec 16, 2009 | Sunbeam 805810 HeatSense Heating Pad...
Soft Heat Micro-Plush Low Voltage Heated Mattress Pad Logo
Top Soft Heat Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Soft Heat Furniture Expert? Answer questions, earn points and help others
