Question about Panasonic PV-V4020 VHS VCR
PV-V4020 is "eating" tapes. I don't have a cleaner tape or compressed air. How can I manually clean the inside of the VCR and/or what may be causing the machine to eat the tapes? Please help!
The VCR hasn't been used in a few years. What can I check to see what may be causing the problem?
  • Panasonic Master
  • 1,511 Answers
It is hungry, that is why.
Posted on Jan 22, 2015
2 Suggested Answers
  • 4234 Answers
SOURCE: Re: Model PV-4523S
The problem is that the "idler" assemby has gotten slippery. This is either a rubber tire or perhaps a gear that is driven by a belt inside the machine. In either case, this is a simple repair and is common as machines age. This should be a $75 repair including parts. The pinch roller (rubber cylinder) is what pulls the tape across the heads in a steady fashion and has no role in keeping the tape inside the cassette. This is handled by the idler assembly and works for FF/REW and PLAY. Also, a cleaning tape will clean the heads but not effect the pinch roller.
Dan
Posted on Jul 30, 2008
Vcr hi-fi light blinking
You just have a dirty main video head. You can get a head cleaner tape or you can buy a tin of Servisol Video 40.
To clean with the Servisol, remove the top cover of the VCR. You will see a big shiny video head. Spray that head with the cleaner. You can also wipe it over with a cotton bud if it is very dirty. It's a good idea to clean all the surfaces that the video tape touches. If you don't know which, when you first take off the cover with the VCR on power, put a video tape in a press play then watch where the tape runs. Eject the tape, then clean with the spray and a cotton bud. You can even spray the cotton bud and then clean with that if you are not happy just spraying into the unit.
Make certain that the sprayed areas are dry before trying a video. It dries very quick anyway.
Jan 29, 2014 | Panasonic Pv-7451 Omnivision Vhs Vcr W/...
Panasonic 13" TV VCR Combo Unit White PV-C1332W put tape in and plays sound but just static shows on all movies?
You need to clean the video head. With these types of sets it's best to use a tape cleaning cassette. I should get a Scotch Head Cleaner Plus tape currently on sale on Amazon for around 4 pounds.
Nov 22, 2012 | Panasonic PV-C1332W 13 in. TV/VCR Combo
Allegro DVD/VCR combo - not reading disk & eating tapes.
Sorry I know very little about the dvd side but my experience with several VCRs is they need cleaning sometimes just like audio tape recorders and players need cleaning. Early in my days of VCR ownership the engineer I used was sick of seeing me and taught me how to clean the heads, guides and rollers myself to restore performance and help prevent tapes being chewed. Head cleaning tapes simply did not reach the parts needing cleaning though the the wet type sometimes helped.
A VCR might work normally for several months and then suddenly it would happen again. Sometimes I needed to do a clean several times in a month. I did have a Sharp VCR once and that had something called an idler reel that would "suddenly" need replacing (several times) due to chewed tapes but other than that manual cleaning did the job every time.
Later VCRs were fitted with a self cleaner that worked well and meant there was no trouble for a long time but when the self cleaner became loaded with filth they actually made matters worse.
Matter of interest, I use clean newspaper and methylated spirit for cleaning.
Oct 23, 2017 | Allegro DVD/VCR ABV511
Tracking will not adjust, continues to roll, have tried manual tracking adjustment with remote, does not work, wondering if I need to clean or adjust something internal to the VCR
Yes take the top cover off and give all the heads etc a spray with Servisol Video 40. That might make a differance. Allow to dry before trying a tape! If the house has a smoker you might need to do a lot of work!
Jun 06, 2010 | Panasonic PV-V4020 VHS VCR
Panasonic PV-DV102
there are 2 causes why your camcorder is eating up the tapes; either the tape head is dirty or there is a mechanical fault inside your unit (something might be misaligned that causes the film to be sucked in).
try to clean the tape head of your unit by using a tape head cleaner, it is like the tapes that you use with the unit but instead of a film there is a cloth like material inside that is used to clean the tape heads to avoid the film sticking to it
if the issue still persists then you should contact your manufacturer and set up a repair for the unit
Jul 02, 2009 | Video Cameras
VCR Tape jumps like the vertical hold is off.
Most VCRs use the channel Up and Down buttons for the tracking
Jun 30, 2009 | Panasonic PV-9662 VCR
No sound on tape after recordind have picture but no sound
Do u have Sound Card or Not . Plug the sound wire from Sound Card and Your Recorded. may fix.
Jun 24, 2009 | Panasonic PV-V4020 VHS VCR
Vcr has started to eat tapes. Put tape in starts to run then stops.
I did not have a problem with a projector tv-it was a vcr. I took it apart-cleaned the heads and used compressed air to blow out the dust.
Nov 06, 2008 | Televison & Video
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Jul 29, 2008 | Panasonic PV-V4021 S-VHS VCR
Vcr eating tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
Panasonic PV-V4020 VHS VCR Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
