Question about Breezaire WKE8000 Wine Cellar Cooling Unit
Breezaire wke4000 display crazy #'s - Breezaire WKE8000 Wine Cellar Cooling Unit
Breezaaire error code
WKC 1060 ARE NON DIGITAL AND CAN NOT DISPLAY CODES,YOUR UNIT PROBABLY IS A WKCE 1060 DIGITAL UNIT IF SO PLEASE CLARIFY WHAT IS THE ERROR CODE ON IT?
Sep 15, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
Display flashing 0.6
THAT IS A BAD CONTROL BOARD ALLSO CALLED A SENTRY III BOARD, YOU CAN CONTACT THE MANUFACTURER 858-566-7473 AND PURCHASE A NEW REPLACEMENT BOARD ITS VERY SIMPLE TO INSTALL AND DOES NOT REQUIRE REMOVING YOUR UNIT.
May 22, 2011 | Breezaire WKL 4000 Wine Cooler
I am trying to recharge my Breezaire WK8000 cellar unit (which Breezaire said could be done), but the unit has Rivits at all corners. How do you get to the compressor to recharge this unit?
DRILL RIVETS OF WITH A 1/8 DRILL BIT AND ADD AN ACCES VALVE.
UNIT SHOULD NOT BE RECHARGED WITH OUT PRESSURE TESTING UNIT AND FINDING THE LEAK FIRST, OTHERWISE THE FREON WILL SCAPE AGAIN
Apr 30, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
I need a wiring diagram for a Breezaire WKE 8000 wine chiller/cooler. Does anyone know where I can download one?
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS.
MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU
858-566-7473 BREEZAIRES NUMBER
Mar 16, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
What refrigerant is use for BreeZaire wkr 1060 and
A WKR 1060 SHOULD BE AN R-22 REFRIGERANT UNIT AND IT SHOULD STATE SO ON THE UNITS TAG ON BACK OF THE UNIT.
I IT IS IN FACT AN R-22 MODEL 1060 IT USES 9oz OF R-22
IF IT IS AN R-134A IT USES 10 oz
Dec 02, 2010 | Breezaire WKCE 2200 Wine Cooler
WKE 3000 temperature panel has stopped working - unit still turns on and off properly.
IF YOUR UNIT IS A WKL IT SHOULD HAVE A SENTRI III CONTROLLER(BOARD) THAT HAS A LCD DISPLAY GREEN NUMBERS ON IT WITH BUTTONS(SET, WARMER, COLLER) IF SO THE ONLY OTION IS TO REPLACE THAT BOARD, A VERY SIMPLE PROCESS 10 TO 15 MINUTES MINIMU TOOLS, CONTACT BREEZAIRE AT 858-566-7473 THEY WILL SELL YOU A BOARD OR CONECT YOU WITH A DEALER TO BUY THE REPLACEMENT BOARD ARROUND $150 APROX
Nov 11, 2010 | Breezaire WKL 4000 Wine Cooler
Unit runs gets only to 62 degrees. Top exhaust clean. 5 yrs old
CONTACT THE MANUFACTURER BREEZAIRE 858-566-7473 THEY WILL CONECT YOU WITH A DEALER THAT STILL MODIFIES UNIT TOP VENT.
BREEZAIRE DOES NOT MODIFY THE UNIT TOP VENT THEM SELF NOR DO THEY SELL DIRECT BUT THEY WILL PUT YOU IN CONTACT WITH THEIR DEALER THAT DOES.
Jun 06, 2010 | Breezaire WKCE 2200 Wine Cooler
Breezaire WKE8000 Wine Cellar Cooling Unit Logo
79 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
