Question about Office Depot ATIVA DX120P Shredder
Doesn't turn on in auto or reverse - Office Depot ATIVA DX120P Shredder
1989 dodge dynasty v6, fwd, transaxle 3 speed auto, good condition, experiencing shift problem, doesnot want to shift into passing gear, sometimes it does, right now it doesn't, any takers
most auto trans don't shift into reverse when low. Reverse takes the most fluid of all the gears.
Check for a bad shift solenoid or wires to and from that circuit. Most trans-axles have them now.
Feb 25, 2013 | 1989 Dodge Dynasty
I got my 2001 dodge ram 1500 with the 5.9L v8 stuck in the sand at the beach. While my buddy was pulling me out from behind, I was flooring it in reverse to get out. Then my my rpm went down and the...
Need more info: is manual shift if so 4sp ,5sp or 6sp speed?
or auto w/overdrive ?
2) wont go into gear or selects reverse gear but acts
like no gear?
3) does forward gears work?
4) how's the fluids?
Jan 30, 2013 | Cars & Trucks
Doesn't work in auto position but works in reverse
Most likely your optic sensor has something in front of it. Clean out the unit really well. It does take time, about 3 different screwdrivers, lon pliers and tweezers and a vacuum or compressed air. After that, learning more new words and swearing to god you will never let this happen again until the third time.
Jan 06, 2013 | Black & Decker BD10P Shredder
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
Shredder doesn't shred.
Shreader wont cut will reverse ok
How to check if Auto Reverse Works
Play a tape to the end. If it reverses, it is working properly.
Make sure that you have turned the auto-reverse feature on. The switch is next to the power button.
Jul 13, 2012 | Audio Players & Recorders
Auto transmision grinds in reverse, put in dr grinding stops but doesn't move
sounds like it is time to get the transmission rebuilt. usually when they go out you will only have reverse. It sounds like the oil pump has exploded inside the trans. sorry for the bad news
May 27, 2012 | Mazda MPV Cars & Trucks
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Although I placed both ends the necessary sensing foil ,when choose auto-reverse with my Akai GX-636 RtR only the right tension arm sense the foil and blocks without reversing.When in recording mode it...
I'm pretty sure the auto-reverse is NOT supposed to work during recording. What would be the point since it only records in one direction?
And I'm pretty sure there's only one reverse sensor, usually to the left of the heads and not necessarily on a tension arm. The sensor foil is supposed to be on the non-oxide side of the tape so it will adhere better and never contact the heads.
This picture of a GX-635 shows a typical transport ...
http://www.oaktreevintage.com/web_photos/Reference_Photos/Akai_GX-365D_Front_Face_Off.jpg
There's a knob for how the auto reverse. Is it set correctly? I believe infinite forward / backward play is possible if you have the knob set properly, a sensor foil on the tape and the tape counter set to 0000 at the beginning of the recording.
May 12, 2011 | Audio Players & Recorders
Office Depot ATIVA DX120P Shredder Logo
54 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
