Question about Cecilware " Fryer, gas, floor model, 40 lb. fat capacity, automatic temperat"
Oil leaking from front plates on fryer tank
Looks like the oil is coming from the small bolts on the plates on the front of the tank behind the burners their are 2 plates left and right side is there a repair kit for this problem
3 Suggested Answers
  • 77 Answers
SOURCE: my deep fryer is leaking oil,how to fix it
Replacing the tank isn't cost effective. I am the only one I know that repairs fryer tanks. Most cannot be repaired(welded) successfully. If you got 8 years out of it..that's not bad. Time for a new one.
Tom
Posted on Aug 17, 2010
kebah
  • 683 Answers
SOURCE: my deep fryers leaking oil
Try to visit http://www.grindmaster.com/foodservice-equipment.aspx, you can check there the nearest authorized service provider in your area.
Posted on Jun 02, 2011
Leaking transmission fluid
Transmission oil is very viscous and will leak from the smallest opening. There is a set tension to do the pan screws up to and if you exceed that setting the gasket squeezes out and the oil will leak out. It is best to use an adhesive sealent on the tranny body first ,put up the gasket let it set for a few minutes . paut adhesive seealnt on the pan and bolt up with minimun bolt tension. After a few minutes retension the bolts correctly. As a firther check remove the inspection plate under the torque converter and check for oil leaks down the front ot the tranny behind the converter.
Feb 23, 2013 | Cars & Trucks
Oil leaking from the bottom of fryer
Do you let in from hot to cold that might do something to it. Need anew one
Feb 09, 2013 | Rival CF153-WM Deep Fryer
My fryer is leaking oil from the tube inside I have a Master Dean fryers
If you are leaking oil by one of the burner tubes you can replace the tank or get a new fryer. new tanks usually cost around 400 plus installation. Usually better to replace the fryer.
Tom
Jul 23, 2010 | Frymaster Dean SR42G Deep Fryer
My pitco gas frialator oil leak in tank .how can
You need to identify where the leak is coming.
If the leak is on the fry tank, best way to address it is to replace the oil tank.
Check the serial number of the unit with leak on fry tank, verify if it is still under warranty at PITCO web on http://www.middleby.com.
Jul 11, 2010 | Pitco Frialator SG14 Deep Fryer
What might be the source of an antifreeze leak? It appears to be coming from the engine front up and to the left of the oil filter on my V6, '95 Camry. I find the small puddle after the car has stopped,...
yes it could be a bypass hose it could be a freeze out plug going bad it may be a bad head gasket it may be a bad water pump these are a few items to check.
Jan 28, 2010 | 1995 Toyota Camry
Oil filter position
The oil filter is underneath the bike in the front where the large square gray oil pan is located. There are two bolts. One is surrounded by a large circle which is about the size of your new oil filter. Remove the bolt and there will be a small washer then the circular metal plate which cups the oil filter. This has a gasket which seals against leaks and inside of the cupped metal plate is the oil filter. Remove replace, and reinstall the parts in the same order. ,,,
Nov 10, 2008 | 2005 Kymco Venox 250
Cecilware " Fryer, gas, floor model, 40 lb. fat capacity, automatic temperat" Logo
20 people viewed this question
Top Cecilware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
john h
Are you a Cecilware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
