Question about Whirlpool Duet GHW9150P Front Load Washer
F05 ERROR CODE COMES ON AND CYCLE STOPS. REPLACED TEMP SENSOR BUT STILL DOES SAME. TEMP SENSOR GOES IN HEATING ELEMENT. DOES THE ELEMENT NEED TO BE CHANGED TOO?
2 Suggested Answers
SOURCE: Error code F05 after the start of wash cycle
error code F05 after the start of wash cycle, what do i do now
Posted on May 24, 2009
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
F-05 error
F05:
Water Temperature Sensor Error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Potential Causes
Check the Water Temperature Sensor, Heating Element and Element Relay • Check connections to the Sensor, Heating Element and Relay
Feb 05, 2011 | Washing Machines
Code error F05
If this is a Whirlpool model the FO5 error code means:
Potential Causes
F/H
F/02
Hope this sheds some light on your problem
kcomp1863
Jan 20, 2011 | Washing Machines
Stop work and is showing a code f 05
Potential Causes
Dec 14, 2010 | Kenmore HE2 Plus Front Load Washer
Two of the baffles broke replaced them now getting a code f05 and washer beeps and wont finish wash cycle
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
Above is your service manual, look in the area of the NTC sensor,it needs to be replaced, the service manual will show you how.
You need to replace the ntc sensor, most likely.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWOEAST912 - Error code F05
Well An F05 is a water temperature sensor error.
This occurs if there is a problem detected during the heating step of the wash cycle.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Element Relay.
But as you says that your washer is only 4 months old so why don't you ask for warranty......
Please post comments if you need more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Whirlpool Washing Machines
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
Potential Causes
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
