Question about LG Microwave Ovens
Lg MICROWAVE solardom mp9488s door handle loose
Door handle loose
silly girl
  • 513 Answers
SOURCE: loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Posted on Apr 30, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: I would like to know
If your owner's manual doesn't cover lamp replacement, you will have to take the oven apart to do it.
If you don't have your manual, you should be able to download it from here.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's here.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Otherwise, please reply back with your model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
  • 19 Answers
SOURCE: replacing handle on LG LMV1680WW microwave
I have never replaced a handle on a microwave. I was looking at mine. If I have to guess how to get to the screw behind the panel, I would guess the inside cover needs to be popped out. Now a day, all the covers are snapped together. Be careful not to break it.
Or look for your manual, or look it up on the web.
Good luck
Posted on Aug 29, 2009
SOURCE: GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Posted on Oct 14, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Nov 25, 2009
Replace door on lg solardom microwave
You need to be carefull. You need a tester to use to check aroud the door after installing door. You should have a qualified tech. check it.
Jul 09, 2016 | LG Microwave Ovens
LG Solardom MP-9483SLA bought 2 yrs ago,
Idont understand the problem pls write the main problem
Sep 15, 2014 | Microwave Ovens
I have an LG solardom microwave and when I want to heat a small amount of liquid, it sparks and the base(not the turntable) of the microwave gets hot.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
Nov 24, 2013 | LG Microwave Ovens
Loose microwave handle
The handle screws are installed from inside the door, so it would be necessary to disassemble the door to tighten them. You have to decide whether the time and labor involved are worth it.
May 19, 2013 | Microwave Ovens
Lg solardom oven innerdoor replacement
go to www.repairclinic.com or www.appliancepartspros.com and buy it
GOD BLESS YOU
Jul 16, 2012 | Microwave Ovens
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
Nov 23, 2009 | LG LMV1630ST Microwave Oven
Solardom microwave won't stop turning
quite possibly the door switch has failed . take it in to a repair shop , if you can find one locally
Oct 17, 2017 | LG Microwave Ovens
Goldstar Mv1526W
I would suugest that you contact LG via their site here: http://lgservice.com/
Oct 22, 2007 | Goldstar MV-1526 Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
