Question about Crock Pots & Slow Cookers
I had a inductor cooker aowa 551co model.the inductor coil not working
Why doesn't it heat?
Your coil has most likely failed. Sorry, but it is probably dead.
Dec 22, 2015 | Bella Dots 6 Quart Slow Cooker - Purple
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Plugged in wont go on. Fairly new. Maybe year old probably from bed bath and beyond. Help
Check for power at outlet. Then check for power at heating coil. If there and still not working the heating element is gone.
May 28, 2015 | Hamilton Beach 33966 6-Quart Slow Cooker
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
I need a manual for miu france pressure cooker model 95080
MIU France produced a video to explain how the pressure cooker works. You can view it here:
http://www.youtube.com/watch?v=qJhVqdx7f9M&feature=c4-overview&list=UUk09IwTBUtsp_BCGLXF6QYw
You might want to check the Free Pressure Cooker Manual library occasionally - if the manual you're looking for isn't there they'll likely add it soon!
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Apr 11, 2013 | Wolfgang Puck Electric Pressure Cooker...
Need manual for MIU France model 95080 Pressure cooker
Sep 07, 2012 | Fagor Crock Pots & Slow Cookers
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
Pics of process:
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
Crock Pots & Slow Cookers Logo
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
