Question about HP OfficeJet 6110 All-In-One InkJet Printer
Konica buzhub 353 cannot receive fax phone just rings
ctf1800
  • 4402 Answers
SOURCE: how to receive fax on my home phone
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Posted on Jan 10, 2008
  • 3 Answers
SOURCE: Incoming faxes
does the hp 5610 need to be hooked up to your pc, does it need drivers?
i bought one used and have it hooked up to my modem 2 into 1-splitter with the phone line in from the wall of the home into the splitter as well as the fax plugged into the splitter.
then my home phone plugged into 2-ext on back of the hp 5610.
why can't i receive a fax/
what am i doing wrong.
i called service provider here in florida and the tech could not even answer if they had specific rings enabled for my service..big surprise automated aggravation for 30 min to get a person that says i dont know..
Posted on Sep 09, 2008
  • 105 Answers
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Posted on Oct 05, 2008
localwonder
  • 6784 Answers
SOURCE: fax does not connect on distinctive ring
Make sure that you have assigned it correctly. You should get a completion indicator or some kind of notification saying that the ring has been assigned to the specific location you ordered. if not, i will not be assigned correctly and it will go back to the default ring.. hope that helps ya:)
Posted on Jan 30, 2009
  • 25 Answers
SOURCE: Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Posted on Feb 28, 2009
Canon mf5770 not receiving faxes
Most fax machines allow you to set the number of times the phone rings before it automatically answers the phone. So if you phone goes to voice mail after 4 rings and the fax machine is set to start the fax after the 5th ring it will never receive the faxes because the call went to voice mail. Good Luck
Dec 05, 2013 | Office Equipment & Supplies
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
Stopped receiving faxes ten days ago. Can still send faxes. Senders say it just rings and rings. Calling the fax by phone confirms many rings, then fax belltones. What do you think is the problem?
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 28, 2010 | Canon PIXMA MX310 All-In-One Printer
FAX DOESNT RING WHEN RECEIVEING CANON FAX-L350
These units only ring under two circumstances. First the external phone must be attached. It has a volume slider on the phone. Second. The recieve mode must be st for Fax/Tel not anything else
Jun 20, 2009 | Canon FAX-L350 Plain Paper Laser
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
12 people viewed this question
Seeker5211
Seeker5211
