Question about Smeg Washing Machines
How do i remove and clean filter on hoover optima
I can't remove the black component behind the crew cap - should0 it be attached to the cap?
3 Suggested Answers
  • 3 Answers
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
Posted on Nov 05, 2009
javeedcare
  • 316 Answers
SOURCE: I have a hoover optima,
CHECK IF YOU HAVE REPLACED THE COVER PROPERLY. IF IT DTILL LEAKS THEN YOU HAVE TO REPLACE THE GASKET.
Regards.
DON'T FORGET TO RATE MY SUGGESTION
Posted on Jul 06, 2011
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
Hoover F7425-900 SteamVac V2
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
When i screw the filter plug back in, the water still leaks, hoover optima wash wmh148df-80
I suspect there is either limescale in the thread of the filter plug OR behind the filter itself and this is stopping the plug from being screwed home. Remove the plug, pull out the filter, clean filter compartment all round, especially at the back AND ensure the plug thread is completely free of limescale ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 15, 2011 | Hoover Washing Machines
I have a hoover optima, and I have just cleaned the filter, when I put the filter back in, water leaks out from it.
Regards.
Jul 06, 2011 | Hoover Washing Machines
Hoover hnl662 - can't remove filter
Had the same problem with our Bosch, cap would not even turn!
Suggestions- (+ loads of patience!)
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
Good luck
John C
Apr 01, 2011 | Hoover Washing Machines
I cant get the brushes to spin on my hoover max extract carpet cleaner
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
Jan 28, 2011 | Hoover Vacuums
My hoover steam vacs brushes will not turn . could there be a belt broken? I have misplaced the manual
For the manual:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
For the brushes:
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
The gear box that drives the brushes is driven by vacuum air, running the turbine inside.
There are no belts, just direct drive.
Mar 10, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes on Hoover steam vac dual v do not turn
Nov 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How do you change the belt on a f7441-980 hoover carpet cleaner
There are no belts on the SteamVac series. If you have a brush rotation problem, please check this:
(4)Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen
Oct 06, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steamvac model # F5915-900 and the brushes are not turning when I turn the selector from off to low or high. I've checked to make sure the brushes are locked in place and they turn manually...
(1) Remove the brush assembly by pulling/unlatching it from base on each side.
(2) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(3) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Sep 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Washing Machines Logo
12 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
