Question about Rane THX 44-THX Home Cinema Equalizer" Shipping" Home Equalizer
POWER CORD WITH PLUG FOR RANE THX 44-THX HOME CINEMA EQUALIZER
2 Suggested Answers
SOURCE: Why does this not work?
hi i am using a sahara notebook but thair driver are not installed even i dont know the model no how i can solved the problem which driver is the best for my notebook will you plz help me
Posted on Jul 14, 2009
Rane me 15 blows fuse
If at off position, fuse doesn't blow
• check shorted/leaky components after the capacitors
such as Q3, Q4 , Q5 and regulators Q1 and Q2
• or simply remove them all, put it back one at a time to find the cause
but be sure to mark , so you can put the good ones back .
Sep 10, 2012 | Rane Me 15 Graphic Equalizer Eq
Plugged in power ac for my rane ttm 56 mixer during a storm....on a cheap power strip and my mixer wont come on....can my 120 power supply have blown or is it sumn wrg with my new mixer? it wont work on a...
Hallo! First you should check with a tester if there is present the voltage at the exit of your power supply, on the cord that goes to the mixer. If there IS voltage (usually 9...15V) then I'm sorry, your mixer is dead. But, for me, most of times is burning the alimentation. Cheers!
May 13, 2011 | Rane Mm8z 19-Inch Mojo DJ Mixer System
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
The problem began with no signal output from Channel 1. Selecting the bypass for Channel 1 results in a signal being output. After complete disconnection & reconnection for bench test, the output for...
change your connection cables with new cables. and bring a good contact cleaner from radio shack near you and apply the spray over all your controls while you are moving them up and down.
Oct 11, 2009 | Rane GE-60 Home Equalizer
Jul 13, 2009 | Rane Serato Scratch Live Computer DJ...
I dont know how to hook up my equalizer to my home theaet system. Please help me out.
You need to connect the THX-44 Between your processor and power amp If you have a reciever you need to use the pre-out / post in order to loop I also suggest using ROOMEQ WIZARD to determine what frequencies to correct.
Jun 27, 2009 | AudioSource EQ-200 Home Equalizer
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
Rane Mixer ttm 54
in sound system you have different sound level start with phono level up to line level up to speaker level.-you will switch to phono when you connect phonograph and you will switch to line when you connect another audio source like dvd and video sound.
Sep 01, 2007 | Rane PE 17 Home Equalizer
27 people viewed this question
Top Rane Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rane Audio Player and Recorder Expert? Answer questions, earn points and help others
