Question about Apex Digital AT1308 13" TV
Problem power suply - Apex Digital AT1308 13" TV
After a lightning stike, the TV will not turn on at all. No lights. Is it the power supply? Is it worth fixing?
is 30% chances that only the power suply is broke, and after a lightning ...is beter to go to a profesional repair shop and check it there.
if the power suply is external before u go to a serice u can try whit a power suply that got same V and A
best regards.
P.S.
i dont wana upsad u but prepare for worst
Sep 22, 2011 | Sony KP-57HW40 57" Rear Projection...
Won't turn on...
you may be forgot to write your printer model. all right-
I think your printer power suply may be dameged. replace a new one.
or, ware, that collect power from power suply is damaged, replace a new one.
thank's a lot.
Feb 09, 2011 | Office Equipment & Supplies
When i push the power buton the powerled go on and few secons off again i used the powercord suply and the battery suply. Could i be the power suply I.C wiht best regards Andre
Hi
Try this. Remove Battery. Hold power button for 10 to 20 seconds Insert Battery and switch system on. Let me know if this works
Oct 01, 2010 | HP Compaq nx6125 Notebook
My akai lcd 32.5" tv will not stay on and all it does is flash the blue screen with akai then turns right back off and i was thinking power suply might be bad. what could it be?
You could be right it sound like the power suply, has it got a AC adaptor power suply,bit like a laptop charger? goes from mains to a black box then from box to the TV?
does it stay on at all?
Oct 01, 2010 | Akai LCT3285TA 32 in. LCD Television
Specification the power suply SDN650PS
For the Bullet camera day/night IR, 18 LED, 3.8-9.5mm the pwer supply is 6mm,12vdc power supply
Oct 12, 2009 | Tyco Electronics / Raychem T312M-Printer
Power suply
Go to www.tigerdirect.com and order one. I suggest going about 25% higher in watts than the one you had.
May 29, 2009 | Dell POWER SUPPLY Power Supply
Sony 52inch projection nothing happens,timer light blinks all the
check powr suply for a sony wite ceramic fuse 0.01 ohm
if open rebuild or replace power suply befor turning on the unit check the H.O.T high v transistor if shorted replace and also replace vdr610 602 and 603, depending on set flyback should be changed also due to a know internal arking problem with sony fly backs.
25% of the time its just the power suply that goes bad.
Jan 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Doesnt turn on anymore.
Hi..there,
It's seems your backlight inverter is burnt out... need to be replaced with a new one or you can repaired yourself by testing all the capacitors to see which it has been burnt out or has a leaked. After that just replaced the bad caps... Good lucks, Have nice a day!
Aug 16, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Apex Digital AT1308 13" TV Logo
13 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
