Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Can't locate the files i backed up - Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
How to open Outlook 2010 email files backed up to a CD?
You will need to import the data from the PST file back into outlook . It should go into a personal folder
After this process you can then copy the files into your email inbox or leave them in a personal folder or create a personal folder on a server mapped drive and then import email data to this folder so it gets backed up hopefully on the server. If you bak up the server..
https://support.office.com/en-us/article/Import-email-contacts-and-calendar-from-an-Outlook-pst-file-431a8e9a-f99f-4d5f-ae48-ded54b3440ac
May 24, 2017 | Microsoft Outlook 2010
How to instol sis file in nokia e63
Hi
Connect the phone to the computer with a cable and choose mass storage or file transfer mode in the phone, After that the phone memory should appear in windows explorer as a drive i.e E:\
Copy the .sis file to a location on that drive you can find your way back to later.
Disconnect the phone from the PC and go MENU - "OFFICE - FILE MANAGER" then browse to the location where you saved the file and run it.
Mar 02, 2011 | Nokia E63 Cell Phone
Hi there how i can fix my outlook erorr without loosing any data
It depends on what version of Microsoft office you use. In 2007 and above, there is a program called "scanpst.exe" that will work to resolve some issues with outlok. (You can locate this by doing a "search/find" for the file name.
You can find your outlook file and back it up too. The file by default is called "outlook.pst" You may want to make a copy before you attempt repair.
The location of the file can be found by opening up outlook. Clicking "File" --> "Data File Management" Click the tab for "Data file" this will display the location of your "outlook.pst" file (or if you chose another name, it will display it there)
Hope this helps.
Nov 06, 2010 | HP Computers & Internet
Hi. I am do a diploma in accounting and have just completed the myob section. I have had to as my first assignment create a company and do a couple of things. Save file and back it up. I have attempted to...
Its possible that the file you are trying to open is now just a shortcut. If you have made a backup, you maybe trying to open a shortcut to a file now located in another location.
Did you manage to make the backup? Does it work?
If this is not your problem, please write back
Jun 30, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
Lost iphoto back catalog after an import, is there anyway to recover these photos?
the back catalog of your images are not gone. Since the pictures you have uploaded form your camera to iPhoto all those files are still there. All you need to do is re-load the images into the library of iPhoto.
1) Start iPhoto, then in the menu goto File / Add to library..
2) Then a file browsing window will open, all you need to do is locate the folder in which u had specified to iPhoto. (Default location for iPhoto is located at MainHD / Users / Username / Pictures / iPhoto Library
3) Once you have located the folder or folders you wish to add to your library or catalog just press import. And all the images should show in the catalog.
4) if you have more pictures saved in another folder, then repeat steps 1 to 3 again. but in step 2 locate the folder or drive you wish to import from.
Jul 07, 2009 | Apple Computers & Internet
Lost files
Have you tried to SEARCH for any file names that you put into that folder? If the search finds a file name that you placed into the folder, make a note of the location of that file, this should help you to locate the missing folder .... it's generally not a good idea to place large files or folders in the desktop, depending on the Windows version you are running. But try the SEARCH for individual file names that you remember putting into the new storage file. Let us know what happens?
Apr 10, 2009 | Sony Computers & Internet
Restoring files to my C: drive
  1. Open shortcutcold.gifBackup.
  2. The Backup Utility Wizard starts by default, unless it is disabled.
  3. Click the Advanced Mode button in the Backup Utility Wizard.
  4. Click the Restore and Manage Media tab, in Click to select the check box for any drive, folder, or file that you want to restore, select the files and folders you want to restore by clicking the check box to the left of a file or folder.
    1. In Restore files to, do one of the following:
    2. Click Original location if you want the backed up files and folders to be restored to the folder or folders they were in when they were backed up. Skip to step 6.
    • Click Alternate location if you want the backed up files and folders to be restored to a folder that you designate. This option will preserve the folder structure of the backed up data; all folders and subfolders will appear in the alternate folder you designate.
    • Click Single folder if you want the backed up files and folders to be restored to a folder that you designate. This option will not preserve the folder structure of the backed up data; the files will appear only in the folder that you designate.
    1. If you selected Alternate location or Single folder, type a path for the folder under Alternate location, or click the Browse button to find the folder.
    1. On the Tools menu, click Options, click the Restore tab, and then do one of the following:
    2. Click Do not replace the file on my computer if you do not want the restore operation to copy over files that are already on your hard disk.
    • Click Replace the file on disk only if the file on disk is older if you want the restore operation to replace older files on your disk with newer files from your backup.
    • Click Always replace the file on my computer if you want the restore operation to replace files on your disk regardless of whether the backup files are newer or older.
    1. Click OK to accept the restore options you have set.
    2. Click Start Restore.
    Jan 29, 2009 | Western Digital 250GB MyBook External USB...
    New route
    From Delphi tech support:
    NAV200 SD Card Reformat
    Problem:
    Customer reports that the NAV200 has lost its voice prompts and/or constantly reads NEW ROUTE.
    Solution:
    Reformat SD card from FAT-32 to FAT. And replace files on SD card with back up files from DVD-ROM.
    Reason for Problem:
    The navlib.ini file located in the navigation files (in mnav) is missing from the SD card. It is located in mnav in the back up files found on the DVD-ROM
    Jun 19, 2008 | Delphi NAV200 GPS Receiver
    Unable to locate back up files in system tools
    try a CD-R, also, under system tools, there should be the back-up option at the top of the menu.
    Jun 07, 2008 | HP Pavilion A250n (DF253A#ABA) PC Desktop
    Lost Blackberry files somewhere in Vista
    what you are using for download try to download the bb desktop software for windows vista from same location then it will take the same path for download write the path and cancel the download then you got the path which you downloaded previously
    Mar 11, 2008 | Computers & Internet
    Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
    16 people viewed this question
    Top Maxtor Computers & Internet Experts
    Computer Links
    Rick Arnold
    terminalcon
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
