Question about SNK Magnavox 42MF231D 42 in. Plasma TV
Magnovox 42mf231 with power supply problem - SNK Magnavox 42MF231D 42 in. Plasma TV
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
I have 8 year magnovox 42' it would turn off by it self now it will not turn on need some help please
At eight years old, likley the power supply is failing. You can try unplugging for a1/2 hour and then plugging it back in to see if you get any power lights or hear any noise. If it makes noise for a second and then cuts out, it is very possible that the power supply has some bad capacitors on it. Depending on your level of technical ability you can either find another power supply or change the capacitors. If you look at the power supply, any capacitor that is bulging on top is bad. Really bad ones will look like they are leaking with a residue on top.
Dec 05, 2014 | Televison & Video
Why TVs shut down spontaneously Magnovox TV
There may be power supply failure issue to your tv. So, what i recommended is to take it to the shop where you bought it if it is under warranty. Repairing it yourself may be danger as there is risk of electric shock. Thank you for asking on fixya.com
Mar 21, 2013 | Televison & Video
Where are the fuses located on a 37 inch flatscreen magnovox?
The fuse can be located on the power supply board. To locate the power supply board, trace the TV wire back into the TV. The area where the TV wire is soldered inside the TV is the power supply board. There is fuse on the board. So this means you have to disassemble the TV....
Regards.
Walesarumi
Sep 28, 2011 | Televison & Video
Will not come on
the problem can be solve by opening the back cover of the television to check for blown fuses but if otherwise the power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Hope this helps...
Jun 03, 2010 | Philips Magnavox 42MF521D/37 Television
My rear projecti Philip magnovox PTV835 has no power ,its plugged up and i get nothing
Call Encompass Parts 1-800-638-3328 or try UED 1-800-649-6657 and you can try shipping your power supply Board to PTS 1-800-844-7871
Nov 18, 2009 | Philips Magnavox 9P6034C 60" Rear...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
SNK Magnavox 42MF231D 42 in. Plasma TV Logo
20 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
