Question about Riccar Vacuums
Power brush makes noise on canister model
Already cleaned brush and pressed reset button, brush not turning before, works now but making loud noise
    Genius:
  • Riccar Master
  • 1,205 Answers
Make sure bearings spin freely. If brush roll is not cleaned frequently enough hair can damage bearings or end caps. f
Posted on Aug 11, 2014
chrispurs1
  • 372 Answers
SOURCE: brush bar does not turn & makes a loud noise
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Posted on Oct 14, 2007
SOURCE: Does not pick up anything and makes weird noise
I had the same problem with very low suction and weird noises, the orange light kept coming on.
I always empty the cannister and clean out any hair from the roller. I would take the filter outside and clean it as good as possible. I don't know if I can post a picture on here or not, but I will try. It is unbelievable how much hair comes from long haired girls. Particulary my daughter. Back to the point...
I was cleaning out a drawer one day and came across an extra filter. I put the new filter on, and its like brand new again!
Man, did I feel like an idiot! Just needed a new filter.
Posted on Mar 19, 2009
VacuumRepair
  • 438 Answers
SOURCE: roller does not turn
When a Dyson DC07 makes this horrible grinding noise, it can only mean one of three things.
The Dyson DC07 uprights use a clutch mechanism to control the brush spinning when you change the floor / carpet switch. When you hear this grinding noise, it's actually the clutch slipping because it can not spin the roller brush. Most other uprights use a belt to spin the roller brush, and if something is stuck in the roller brush it will cause the belt to break. Dyson's however will make that awful grinding noise rather then breaking the belt, and will only make that noise if the roller brush can not spin.
When you hear this noise on a Dyson, it can only be 1 of 3 things. Either your clutch mechanism itself has gone bad, or the roller brush itself was not properly put back into the vacuum, or the brush itself has gone bad.
I'll be happy to walk you through step by step on how to diagnosis this problem and find out which one of these two parts is bad on your vacuum2_bing.gif.
Step 1. Make sure the vacuum is unplugged. Then turn the vacuum upside down so that the brushes are facing up. It's easiest if you put the head of the vacuum on top of a bench, or counter top. This is how the vacuum should look:
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner2_bing.gif. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the completely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some maneuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
Step 4. Once you get the belt out of the vacuum cleaner, it's time to test it. Use your finger tips to hold just the end caps on the very end of the roller brush. While holding just the end caps, use your thumbs to try and spin the roller brush. Does the brush spin freely? It should rotate completely several times on each spin. If the brush doesn't spin, or you feel some kind of resistance to the brush spinning, then this indicates that your roller brush has gone bad. Here's a picture of how to test the brush:
If the roller brush went bad, then you'll need to purchase a new one. Here's a direct link to the roller brush your machine uses on our website GoVacuum:
http://www.govacuum.com/dysondc07.html
If the brush however was able to spin freely, and it spun multiple times, this indicates that most likely the brush was not put back in properly, or it could be a little more serious of problem in the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. There is a very helpful video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
I think more likely however it's probably that the brush was not put back in properly, and this caused the brushes not to be able to spin, which would cause the clutch to make that horrible noise. Make sure that the roller brush is pictured like the brush above, you may also want to make sure that the bottom plate is put on correctly, this could also prevent the brush from spinning:
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
If you need to replace the clutch, here's a direct link to the clutch your Dyson DC07 uses on our website:
http://www.govacuum.com/dydcclasfore.html
Here's the video on how to replace the clutch:
When you hear that grinding noise, it can only be one of these three problems. This clutch mechanism was so problematic that Dyson removed it on the second series of the DC07 models. I hope that this repair was helpful in diagnosing your problem. If you have any questions about the diagnosing, or the clutch change, please feel free to use the Clarification Request form here on the Fixya repair page. If this was helpful you, please be sure to rate my repair as helpful by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Posted on Apr 07, 2010
VacuumRepair
  • 438 Answers
SOURCE: Same problems - power nozzle motor does not work
This is a pretty common problem on the Guardian, and it's usually caused by 1 of two things. Both are pretty simple fixes. The first thing you should try is simply eliminating the wand assemblies from the vacuum cleaner. So remove the hose from the upper wand, and disconnect the lower wand from the power nozzle. Now try connecting the hose directly into the power nozzle and turn on the vacuum cleaner, and power nozzle. Does it work? If yes, then one of your wands has gone bad, and you'll need to replace it. Here's a link to the wands on our website if you need purchase a new Guardian wand;
Electrolux Guardian Replacement Wand Assembly
If the power nozzle still won't come on, then you may have a much simplier problem. This is either a terrible design by Aerus, or they knew this was going to happen, and made it this way so you'd have to take your machine into to have them service it. It's a very simple problem usually.
Look on the neck of the power nozzle. You will see a small circle indent on the front part of the neck located underneath of where the wand connects into the neck. This is actually a cover that hides a screw below. Simply use a small flat head screw driver, and pop off the small circular cap that hides the screw. There is a Star bit screw underneath. I believe it's a T15, but it may be a T10 sized screw. Use I believe a T15 Torx screw driver and remove the screw from the neck.
Once the screw has been removed, Use a flathead screw driver, and pry the front cover of the neck off. It shouldn't take a lot of force, and should come off pretty easily. Once this has been removed, you should see to metal pins, and two lead wires. What happens is the lead wire becomes disconnected from the metal pin, which then prevents the power nozzle from turning on. Simply reattach the lead wire into the metal pin, and snap the front cover of the neck back on. Put your screw back in, and your screw cover (or you can just leave this part off, you'll probably be having to remove it frequently to reinstall the lead wire, lol).
If neither of these two problems fixed your machine, then it sounds like you may have a bad hose assembly. Hopefully this isn't the case, and it's usually not. 9 times out of 10, it's just the lead wire that's come loose. If you do however need to buy a hose, here's a link to the Guardian hose on our site;
Electrolux Guardian Replacement Electric Hose Assembly, Blue Color
If you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Jan 08, 2011
Testimonial: "Chris explained how to fix the exact problem that I have - even though I located the problem before reading his solution, he was spot on. Thanks."
  • 262 Answers
SOURCE: Roomba 530 makes a thumping noise every secondand ...
You also need to pull off the yellow bearings from the end of the brushes (one on the brush one and one on the rubber one) and remove hair from the axle there.
Posted on Jan 19, 2011
After replacing belt it started making too much noise when you turn on. What could be the reason?
You missed something then.. look further back in the vacuum stream or belt drive area for debris or foreign objects.
Nov 11, 2015 | Bissell Bissel PowerGroom Pet Canister Bag...
Shark nv350 making loud noise when switched for carpet
HI, it's Jim from Crucial Vacuum!
If your Shark NV350 vacuum is making loud noises when switched to carpet then there are a few parts of your vacuum you can check to resolve the problem.
First thing let's check your vacuums canister. The idea is to prevent clogs and anything that will obstruct your vacuum from operating properly, and running smoothly without noise. You'll want to empty your canister after every use.
Secondly, let's check out your brush roll. Is there hair wrapped around the roll itself, or any noticeable debris that would prevent the brush roll from turning? If so remove it and manually rotate the brush roll to help unearth any hidden clogs behind the roll.
While you're examining your vacuums brush roll take a look at the belt as well. If the belt isn't wrapped around the brush roll properly this could be causing the noise. The belt should have a good bit of tension on it in order for the brush roll to turn properly. Your vacuums belt should be replaced roughly every 3 months. So be sure it's on properly and has a good bit of tension.
You can purchase replacement parts for your Shark NV350 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV350&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim
Crucial Vacuum Customer Care
Mar 19, 2015 | Shark Navigator Lift-Away NV350
Why is my hoover spin brush making a loud noise when i turn it on
Check for clogs starting with the air passageway at the bottom.
A piece of TV cable or similar works well as you have to snake
it in. Check all hoses, Are the filters clean? If you can, remove
the brush bar and belt then turn vacuum on. If the vacuum is
no longer making a loud noise the side bearings on the brush
bar are the problem...replace the bar or spray a bit of WD40-
if you do that wipe well before you vacuum. Finally....if the
vacuum was still loud with the brush bar off...you have a motor
problem and that could be expensive.
Regards.
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I CAN'T TURN MY VACUUM ON.
Use the button on the canister to turn it on but make sure the variable speed is also turned on.
Mar 11, 2013 | Fuller Brush FBPTCAN Bagged Canister...
Now that I just fixed my Lux Legacy canister vacuum, I need help on my other Electrolux Regency Series upright! The vacuum works fine but the rotating brush does not work and the brush motor does not turn...
There are a couple rectangular holes on the bottom of the power nozzle, beside the wheels. These have tabs in them that need released with a standard screwdriver.
rogerpotts_10.jpg Once they release, turn the vacuum over and lift cover of power nozzle at the back. This pulls the front of the cover out of the lip on the "bumper".
Once this is done, you'll need to unscrew the screw at each end of the brush. Lift the brush out and thoroughly clean it, including the ends.
Check the wiring to make sure they're connected to the terminals of the motor. Also, check the belt for wear and tear. These belts can last for five years or more, but if it looks bad a good time to replace it is while you have the power head apart.
When reassembling the vacuum, ensure the belt is fitted properly around the motor shaft and brush.
Insert the front of the cover first, ensuring the edge fits neatly beneath the lip on the bumper all the way around. It takes a little manipulating to press the back into place. Make sure both tabs click into the locked position. Turn the vacuum over and reinstall screws. Try to rotate brush by hand a few times.
At this point, plug the vacuum in and turn it on. If the power head doesn't run, press the reset button. If the power head motor still doesn't run, it could be due to loose or disconnected wires that lead to the reset switch, a bad reset switch, or even a bad motor. The vacuum needs to be taken to the nearest Aerus Electrolux store for further diagnosis and repair.
http://www.aerushome.com/storelocator/
Jan 09, 2011 | Vacuums
Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
Power nozzle motor will not turn on
Try hitting the reset button,It is a small button on the top of the brush and make sure the switch is turned on on the handle.
Jun 22, 2009 | Electrolux Epic 6500 Vacuum
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
57 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
