Question about Cellet EBCEL39 Bluetooth Headset
How to connect to phone - Cellet EBCEL39 Bluetooth Headset
How to connect my xperia x8 as a modem to connect to my laptop to use internet?
you can connect it by data cable or wirelessly by bluetooth once it is connected to your computer open the program for your phone (it comes in dvd/cd with phone)
then select connect option to connect internet from your phone as GPRS or modem as you need
remember when you first time connect phone with computer it shows notification new hardware found and installs your device as standard modem also you can select your phone as modem in control panel also
further the same procedure to make new connection
good luck
Aug 20, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Tip
How to Connect a Cell Phone to Computer
Cell phone has become an essential part of both domestic and professional life. But due to its small size, it is very hard to use its features for long time. However various technologies have been introduced for connecting the mobile phone with computer for getting its services in a simplest environment. By connecting cell phone with computer, you can get access to use various services of cell phone at your computer's screen.<br /><br />The most notable benefits of connecting cell phone to computer are:<br />- It allows you to write long text in your cell phone through your computer's keyboard.<br />- It allows you to transfer play lists from PC to Cell phone or vice versa.<br />- It allows you to transfer pictures and video.<br />- It allows you to use your cell phone as a gateway for Internet access<br />- It allows you to use your cell phone's camera as web cam. <br /><br />Ways of Connecting Mobile Phone to PC<br />Modern technology has been introducing various ways for connecting the cell phone to computer. Some of the most common technologies are:<br /><br />Connectivity through Infrared:<br />Infrared technology offers several important advantages as a form of wireless communication. It allows your cell phone to connect with your computer but it has some drawback as well. It is found in most of the cell phone, but for connecting with your computer, you have to buy a separate device because infrared connects with other infrared device by joining both devices. If they separate for a while the connection would be broken. Moreover, its connecting speed is too slow as compare to other technologies and due to its slow speed you cannot connect your cell phone's camera as PC's web cam.<br /><br />Connectivity through Bluetooth:<br />The most common technology for connecting cell phone with other device is Bluetooth. As compare to infrared, Bluetooth has more advantages for connecting the cell phone to your computer i.e. It is faster than infrared, it detect other Bluetooth automatically instead of joining the devices, you can easily transfer files through it, etc. but it has drawback of buying a separate device for connectivity because most of computers do not has built-in Bluetooth.<br /><br />Connectivity through USB:<br />The cheapest but easily accessible way of connectivity is USB connectivity. It is found in both devices - cell phone and computer. All new computers have USB port and all latest mobiles have USB cable for connectivity purpose. You can easily connect your cell phone with your computer through this cable and software - software CD usually comes with cell phone and also available in market.<br /><br />
on Apr 12, 2011 | Cell Phones
I have problem connecting my mobile to pc
hi! nothing to worry!
u need a data cable enabled phones for connecting! if yes then u need a data cable or a bluetooth dongle(please note that ur phone has bluetooth). then the proper operating system required for connecting ur phone with computer! for example windows xp is the operating system that u will able to connect ur phones easily! then u need to install driver software for connecting computer and access the phone and also for connecting internet via phone to computer! that's it! please specify the phone model! that i'm ready to tell how to connect that ur phone with ur system! Please comment me if u like my solution!
Jul 22, 2011 | Cell Phones
I have S5350 model mobile, how can i transfer photos from mobile to my laptop?
Try to connect it in bluetooth connection. (Wireless connection.). Or try to connect your phone in USB connection. (Wired connection) For wireless connection:
-open your first your bluetooth connection. (phone and laptop) -send the the files/photos via bluetooth connection. -accept the files from your laptop.
For wired connection: -connect your usb to your phone -set your phone connection to mass storage -connect to your laptop, if your laptop detect your phone, search your files, then copy it.. =)
May 21, 2011 | Cameras
How do i connect my phone to my computer
There are two ways you can connect your phone to your computer.
1) Using the cable which connect one end to the phone and another end which connect to the USB
port of your computer. After connecting the phone, you can see your phone, by visiting My
Computer. Your phone will be listed in harddrive portion
2) The other way is to connect your phone using bluetooth technology, for this to happen your pone
must have Bluetooth technology as well as with your computer. If your computer and phone
both has bluetooth technology,
a) Turn on bluetooth device on your phone as well as your computer. Then from your computer,
you can discover your phone. After searching most computers will give a code to put in the
cell phone to pair. Enter the code and computer will pair with your cell phone
Try your luck!! :)
Apr 03, 2011 | Samsung Cell Phones
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
How to conect noika 6030 to mycomputer
To connect internet on your computer with mobile phone,
1. You need a means of connection from your cell phone to your computer or laptop (inferred,bluetooth or data cable), a dial up connection, your proxy settings
steps to connect internet with mobile phone to PC.
Step 1:Take your gprs enabled cell phone and connect it to your computer or laptop using either bluetooth,infrared or a usb cable.
Step 2:Create a dial up connection.Go into your control panel,then into internet options.Then go to connections and add.Create a dial up connection and when it asks for a phone number type in *99#
Step 3:On your new dial up connection add the same proxy address you have on your gprs in your cell phone.
Step 4:Now on your c panel there should be something called modem options here you must change the APN to whatever your APN is on your gprs in your phone.
Step 5:Go to start menu and connect,then connect to your dial up (make sure your cell phone is connected to your computer or laptop)
Step 6:Start your browser (internet explorer,opera etc) and start surfing the net.
Hope it helped.
Thanks for using fixya...
Jan 26, 2011 | Nokia 6030 Cellular Phone
My W810i phone is not connected to pc suit even my phone is connected by USB cable
Thank you
My Problem of not connecting my phone to pc suit is solved.
by running pc suit cd only.Ok
Sanjay
May 20, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
Jul 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Connecting new phone
NO PHONE CONNECTION??? DAH!!!!!!!!!! u have to be mopre specific,u done have a fone connection means ur not able to connect ur fone to other fone or u dont have a number for ur fone?WAts ur issue exactly?
Jul 14, 2008 | Nokia N73 Cellular Phone
Cellet EBCEL39 Bluetooth Headset Logo
19 people viewed this question
Top Cellet Radio Communications Experts
eradiostore
eradiostore
Are you a Cellet Radio Communication Expert? Answer questions, earn points and help others
