Question about Whirlpool GB2SHKXL Bottom Freezer Refrigerator
Freezer doesn't cool to 0 even though it's set at -5
Our unit is only 16 months old and just noticed things in the freezer not solidly frozen. Upper fridge is fine, but freezer not cooling low enough
  • 161 Answers
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Posted on Feb 13, 2014
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
rpbuice
  • 161 Answers
SOURCE: FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Posted on Feb 13, 2009
SOURCE: My Whirlpool cb18m Fridge Freezer works fine but
check to see if the evaporator fan is working in the back of the freezer panel
Posted on Jul 20, 2009
woodchuck789
  • 4066 Answers
SOURCE: The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Sep 06, 2009
  • 834 Answers
SOURCE: freezer is making frost, fridge side doesn;t seem
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is actually that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism. The defrost heater coils can easily be checked by dis-connecting them and using an ohm meter, and a high or an infinite reading would indicate a faulty heater coil, however most of the time they are easily identified as being bad just by looking at them.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
Posted on Sep 24, 2010
What is causing water accumulation in bottom freezer
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You have one of two problems:
1.) Frozen Drain:
You unit goes through a defrost model every 8-10 hours. At this time everything shuts down with the exception of the unit lights. Then, your defrost heater turns on for 20-30 minutes to defrost your cooling (Evaporator) coils. If you have a frozen drain the condensate has no where to go except on the bottom of your freezer. This is a common problem.
A trained technician would pull the back wall out of your freezer, access your drain, clear the drain and put a heat sink in the drain to prevent this from happing in the future. This is a major task even for a technician. This will cost you about $350.00.
You can try unplugging your unit for 24 hours and let the ice melt.
2.) Refrigerant Restriction:
In the upper right had corner of your cooling (evaporator) coil is a small 1/16" diameter tube with a inside diameter about the size of a small needle. This is where it is common for refrigerant flow to get blocked. This is where the high pressure liquid refrigerant turns to vapor. If there is a blockage, a large block of ice forms and drips water into the bottom of the freezer. Also, your cooling coils will not have a full frost pattern. You will get cooling and after a month or a couple of months gradually no cooling.
A repair of this nature is about $500.00 +.
Rule of thumb: "If the repair cost is 1/3 or more of the original cost of the unit - buy new."
Here is what I suggest; Unplug your unit for 24 hours. If after 1-2 weeks the water problem reoccurs. Purchase a new unit. Go to a Sears Outlet Store. Purchase a scratched unit. Save $400.00. The unit comes with a full one year warrantee.
If you decide to go with the repair, go into the Sears Home Services site and print out a 10% coupon on services.
Feb 10, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
During heavy frost everything froze solid even drainage pipe. I notice that my freezer (top half) is not cooling at all. All food has gone soggy. Fridge is just cool.Will it right itself once kitchen...
It's possible the unit is not working correctly as it expects the air temperature to be around 18 degrees centigrade. If too cold, they can go into a defrost cycle.
If your food is not cold enough - but your room is frozen - can you pack your freezer items in snow? Alternatively, move the unit to a warmer area.
Sounds strange - but modern units don't work well in the cold !
Dec 25, 2010 | Refrigerators
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
...The temperature in the frig is now + 40 degrees
uve probably got a freon leak check to see if compressor is running and fans inside are blowing if so then u probably have a freon leak
Feb 24, 2010 | Kenmore 63822 / 63824 Bottom Freezer...
Defrost problem
No there is nothing to reset. It could be one of three things. Let the unit defrost completley. Take the same back pannel off. Check to see if your heater at the bottom is discolored or if you can see thats its broken inside. The next thing it could be is the limith switch which is located on the top of the evaperator. If both those seem fine you can go to the back of the unit and check the main control board. Most of the time its the heater though.
Good Luck
Jul 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Oct 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Fridge fine, freezer not freezing
Weird scenario... the first thing I would do it to remove the interior back panel of the lower freezer section after the unit has been running for hours and check the coils to see the frost pattern on them. Should be even white frost all over the coils with no solid frozen coil (block-O-ice thing). Check the fan is running above the coils, etc. when. If everything is OK then you may have a control board problem. Let us know what you find in the freezer coil investigation and we can go from there.
Jan 15, 2007 | Samsung RB2155SH Bottom Freezer...
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Whirlpool GB2SHKXL Bottom Freezer Refrigerator Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
