Question about Bang Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone
Tried to re register handset to base, tell me , wait, then does not configure?
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
Hi, I have a DECT2085-3 base with 3 handsets. I would like to add another handset. I bought two used handsets and would like to register them to my original base. I am having trouble with the selecti
In the instructions you need to find how you Sync the base and add that number phone to the base. All have different ways so try the company website on google.
Dec 09, 2014 | Uniden DECT2085-3 Trio Cordless Phone
I have a unden dcx150 and i tried to register a handset accssory but keeps coming uoregistration failed
Mar 24, 2011 | Uniden DECT 6.0 Cordless Phone ID
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Nov 12, 2010 | Uniden Lands Phones
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
Simply can't register any of my 4 handsets with my BT Synergy 4100 cordless phone. All handsets indicate base is "unavailable" there isn't a fault on the line as I have tested it and I have gone over and...
Partial solution. The handsets may be registered to another base.
So go into handset setting, then select base, (select another base if there is one showing).
Then go through the handset registration procedure again.
D
Jun 20, 2009 | Cell Phones
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
Bang  Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone Logo
49 people viewed this question
Top Bang Olufsen Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Bang Olufsen Lands Phone Expert? Answer questions, earn points and help others
