How to connect bsnl broadband in dgnd3700 - Computers & Internet
Benimur
  • 6966 Answers
SOURCE: BSNL Broadband connection
In brief yes. 2 possible ways:
1. Use a router; or
2. Configure 1 of your PCs to be the Default Gateway and enable Internet Connection Sharing (this is where the single user broadband connection must be plug in). If your modem uses USB connection to the PC (Gateway), use the LAN card IP add as the Default Gateway of the other PCs in your network. If your modem uses the Ethernet port, you need to install a 2nd LAN card on the same PC and do the same configuration.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Posted on Nov 13, 2007
Dionnow
  • 61 Answers
SOURCE: how to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Posted on Feb 09, 2008
SOURCE: BEETEL 220BX ROUTER
First login to your Router using default username and password
2. Click on WAN on the left side menu
3. You'll have options to add or remove configurations.
4. Please select and remove the bridge config as BSNL does not support Bridge.
5. Please click edit on the existing PPPoE Airtel Configuration
6. Set the VPI=0 and VCI=35 (for Airtel it would be 1,32) and click next
7. Select PPP over Ethernet (PPPoE) and encapsulation type: LLC/Snap Bridging and click next
8. Enter the following details:
PPP Username: Your bsnl username (no need to add dataone.in)
PPP Password: Your bsnl password
PPPoE Service Name: DataOne
Authentication Method: Select CHAP
Click Next
9. Check the Enable IGMP Multicast Option
Check Enable WAN Service Option
Enter the Service Name as Dataone
10. Click Next and Save. You should also save and reboot your modem.
If doing the above does not works, check if you have anything set Under TR-069 Client and remove all entries in this section however it may not allow you to save so you may just put the ACS URL as ( it won't accept this field to be blank so just enter any thing, I entered http://bsnl). Save and reboot the router. Should be online now.
let me know if anyone benefited from the above information - abialexin@yahoo.com
Posted on Jun 18, 2008
  • 44 Answers
SOURCE: adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
Posted on Apr 11, 2009
kvgopi
  • 73 Answers
SOURCE: i cannot connect to by bsnl broadband modem with laptop
Please check your DNS settings. If you dont know your DNS settings you shall use the global DNS server 4.2.2.2
Posted on Jun 09, 2009
Bsnl broadband modem
Indian Telecom gaint Bharat Sanchar Nigam Limited (BSNL) has introduced 4 types of ADSL Broadband Modems(ADSL Basic Modem(CPE), ADSL WiFi Modem, ADSL WiFi-TA Modem & VDSL WiFi Modem) with Ethernet, Wi-Fi , USB, and Terminal Adapter port.
Which version have you got?
Feb 10, 2014 | Acer Computers & Internet
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
I am unable to open many sites while using bsnl broadband..
BSNL have aways been known for its network problems
there are many websites actully lakhs of domains who are not authorised for use in bsnl domain.
SO. its better you try switching to some other broadband or 3g connections other than bsnl
Dec 27, 2010 | Computers & Internet
Sir The belkin wireless router is not responding in BSNL PPOE broadband connection what is the way to get connected through the ISP of BSNL. murali
IF u are using the BSNL broadband connection, you might be having a modem provided by the BSNL, 7230 model is only a router, it doesnt have modem option so all u have to do is
1. Go to belkin page 192.168.2.1(if u changed the ip address in router, then type the default gateway of the router)
2. Click on connection type
3. Setup as a dynamic connection since the PPPoE is already set on the modem
4. Follow the on-screen instructions
5. Check the internet status, if its still showing as not connected then powercycle the router for 15 sec and then reconnect the cable
Hope it will work
Sep 29, 2010 | Belkin (F5D7230-4) Router (587009)
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
I cannot connect to by bsnl broadband modem with laptop
Jun 04, 2009 | Computers & Internet
How to see bsnl broadband bill on net.
use dataone.in their check your account status to check your bill
Apr 11, 2009 | Computers & Internet
Sharing
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
