How do you replace a fuser unit for a Brother HL-6180DW
    New Friend:
How to solve hl-brother printer 6180dw power on off print unable to print ef triy again back
Posted on Feb 24, 2017
  • 130 Answers
SOURCE: Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Posted on Nov 19, 2008
  • 56 Answers
SOURCE: Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: Re-attach fuser cover on Brother HL-4040cn
I had the exact problem. Had to order a new fuser unit, as this is not a serviceable part. But I took pictures for future reference. CLICK HERE.
Service Manual I found online for free download
Posted on Sep 23, 2009
SOURCE: brother hl-5250dn fuser unit faliure
I have 2 printers that dosn´t work. Brother HL-5250 dn One with fuser that dosn´t work. Can I take thee fuser from the other and attach it into the first one. Or do you ned spcial tools and knowldge to do it?
Posted on Mar 10, 2010
  • 2386 Answers
SOURCE: Help me with reset fuser
HelloTo reset fuser on your HL-5270DN you have to press "Go" and "+" at exactly the same time. You will be given an extended reset menu. Then you will go for fuser reset.
Plz sure the fuser must be OK/replaced before applying this action
Good luck
Do rate the solution if got help
Posted on Dec 06, 2010
How do I replace the fuser in a Brother 2460?
This is a technical procedure. But if you are up for it follow the links below which should give you enough details presuming that you have purchased a new fuser unit.
How to fix fuser error Brother HL 2460 printer
Jan 15, 2015 | Brother HL 2460 Laser Printer
How do I reset the Replace Toner message on a Brother HL-6180DW?
  1. Ensure the printer is turned on and otherwise ready to print.
  2. Press the front cover release button to open the front cover of the printer.
  3. Remove the drum unit with the toner cartridge installed from the printer.
  4. Now re-install the drum unit and installed toner cartridge slowly but firmly.
  5. Press and hold the Go button until Drum Clear appears.
  6. Close the front cover of the printer.
The "Replace Drum" message should now have disappeared and the LED no longer lit allowing you to continue printing
Sep 02, 2014 | Brother TN-780 Black Toner, Super High...
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
How do I reset the drum counter on a Brother HL-6180
Press the "GO" button and the "Arrow UP" button together(Go button first),
Then press "OK",
Then press the "Arrow UP" button again.
That's it!
Feb 26, 2013 | Brother HL-6180DW Monochrome Laser Printer
Reset counter brother printer hl-6180dw
By 'Counter' do you mean Toner Counter or Drum Counter?
For Toner Counter - This is done by the gear on the side of the cartridge. The gear when looking at it travels counter clockwise lifting outwards as it passes over a mount in the fill cap. Starter Cartridges do not have the gear in place and this needs to be put in when refilling the cartridge.
For Drum Counter - Have the front of the machine open (As if changing the cartridge) and press the Go button on the machine till the display reads Drum Changed or Drum Accepted.
If it requires you to press the back button then it will have a message "Change Drum" with an up arrow and down arrow for yes and no.
Feb 04, 2013 | Brother International HL-6180DW hl6180dw...
Error fuser unit hl-5350Dn
The fuser unit is located at the rear side of the printer.
Fuser unit error indicates one/more of the following.
1. The fuser roller/film life is over. Replace with new one
2. The fuser film is torn. Replace with new one.
3. Fuser heater is burnt. Replace the heater.
4. Fuser thermal sensor is open. Replace it.
Jun 28, 2011 | Brother HL 5250DN Laser Printer
I have replaced the fuser on Brother HL-4070cdw but the screen displays fuser unit end How do i clear the message Thank you
Look on page 115 under maintenence. Follow the instructions down to where it says Belt Unit, instead, find Fuser Unit then continue with reset instructions. Hope this helps.
Oct 27, 2009 | Brother HL-2040 Laser Printer
Is it possible to replace the fixing unit yourself on the Brother HL 5170DN?
You can, it just takes patience. Removing covers, screws and plugs for the fuser is pretty simple. You can find a fixing unit at just select your make and model and then fusers and parts.
Jul 29, 2009 | Brother HL 5170DN Laser Printer
Brother hl-5250dn fuser unit faliure
Jan 19, 2009 | Brother HL 5250DN Laser Printer
Paper Curling with Brother HL-2040
Replace fuser assembly/have fuser unit replaced if you have tried fresh quality paper from a unopened ream. The first versions of these had the fuser and exit assembly modified by brother to help eliminate excessive curl last 9 digits of serial number are higher than D5J760210 have already been modified, if lower ie D4Z99999 need to get mod. fitted.
Jan 10, 2008 | Brother HL-2040 Laser Printer
1,258 people viewed this question
