Question about Compaq Evo N610C Notebook
Upgrade HDD for Compaq N610C
I would like to know the compatibility for Compaq N610C will support Seagate's 120GB HDD??
I want to upgrade the HDD for N610C
Do I need to update my bios?
  • 83 Answers
Re: Upgrade HDD for Compaq N610C
You shoulda known that from the start seagate is compatible with most laptops especially 10 years old or younger
Posted on Oct 28, 2007
0 characters
3 Points
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
I want to know if i can upgrade HDD to 120GB
Most newish laptop HDD now can be upgraded up to about 500GB should be fine if you google harddrives or look on ebay you should find one that you want weather it is sata or ide
just make sure that you check what sort you have before you buy
happy hunting
Nov 15, 2010 | Acer Aspire 1642WLMi Notebook
What is the largest HDD compatible on a Sony Vaio VGN FS630/w laptop What max HDD size can I upgrade now? Currently my laptop has 80GB HDD.
That model laptop will take anything up to 500GB and yes you can upgrade now or whenever you want.
Aug 07, 2010 | Sony VAIO VGN-FS630/W Notebook
Can I upgrade my 80 gb intel core 2 dual hdd to 120 on flybook V5
Hi there, yes you can upgrade your 80GB to 120GB hard drive on your Flybook V5. Toshiba makes a great drive for this. If you need instructions or help however, I was able to get all my questions answered by emailing . I could not get through to anyone at Flybook directly however. :o(
May 20, 2010 | Microsoft Dialogue Technology Flybook V5
I was given an IBM laptop t41 without a hard drive.
it will support any standard ide hard drive
Mar 18, 2009 | PC Laptops
HDD Upgrading
Of cause you can upgrade the hdd to 160GB, the system will detect it, don't worry.
Meanwhile, make sure you have the drivers ready for all the hardware, as new new hdd need to be install with a new windows, and u will need the driver for all the hardware to function properly, like wifi and video.
In case you lost your driver disc, here's the link for you to download
Your rate for my solution is much appreciated, thanks.
Jan 09, 2009 | Compaq Evo N610C Notebook
HDD upgrade for compaq evo n610c
i have a compaq evo n610c with a 160 gig hardrive and a gig of ram a bluetooth top adapter and installed a wireless card with antennas it works fine and reads the hardrive fine and i get the 158 sumthin sumthin gigs that it alwase turns out to be the fans a going harder thoe thats bout it and the batt dies sooner
Nov 27, 2008 | Compaq Evo N610C Notebook
Blue Screen of death
According to this link, the memory of Compaq Evo N610c can be upgradable to 1024 mb.
Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your Compaq Evo N610C to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system. (Souce:
So you have to install 512mb memory module on each slot to make up 1024mb of memory.
Did you install 512mb memory module on each slot or did you just install 1GB memory module in one slot?
Try to go back to 256mb RAM and see if you will have the same blue screen error. If you did not receive any blue screen, try to add memory into it or just insert 512mb first and then oserve again if you will have the blue screen error.
You may also want to go to these links for other suggestions.
May 08, 2008 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
172 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
