Question about GE Nautilus 24" Built-in Dishwasher
How to replace Electric cord
Where do I hook up the 3 prong cord to?
5 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: what type of power cord ( 3 or 4 prong) for an electric dryer
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Posted on Jan 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: Electric GE Dryer will not heat up
GE DRYER WISDOM
Posted on Sep 15, 2009
  • 401 Answers
SOURCE: CanI change a 3 prong electric dryer into a 2
No.
Posted on Jan 03, 2010
heatman101
  • 43501 Answers
SOURCE: I want to replace the
Yes, it is okay but it may not meet code in many areas...
heatman101
Posted on Nov 27, 2010
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
How do i hook a 4 pronged cord into a 3 pronged dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2010 | Whirlpool LER5636P Electric Dryer
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
GE Nautilus 24" Built-in Dishwasher Logo
16 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
