SOURCE: Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
SOURCE: IBM Wheelwriter 6 ribbon not advancing
Befor you put a nrw motor in try a few drops of light oil on the m
motor bearings (WD40 works well).
DickyO
SOURCE: IBM Wheelwriter 3 will not type
Probably the plastic cap on the print soleniod is broken. They are available from us for 15.00 but a little tricky to install.
DickyO
SOURCE: My IBM wheelwriter typewriter will not type..
Chances are that the plastic cap on the print solenoid is cracked.
DickyO
SOURCE: IBM Wheelwriter won't type
MY TYPEWRITER GOES ON FINE, BUT WHEN I TRY TO TYPE THE CARRIAGE DOES NOT MOVE TO TYPE THE KEYS.
