Question about Kenwood TTP102 2Slice Toaster
Toaster stays down and burns toast - Kenwood TTP102 2Slice Toaster
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Hi i have a four slice toaster it is only 13 months old but one side does not work please can you help as i think this should last a lot longer as it was not cheap i dont think it is fit for purpose i
Hi, Try to set the toaster to a darker setting. this will make the toast stay down longer. But keep an eye on it as it can burn. As for the other side not working. Unplug it and look carefully at the heat coils.
If there is a break in the wire you will have to take it to be repaired. Good luck.
Jan 12, 2015 | DeLonghi Toaster Ovens
Control lever will not stay down
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
Apr 08, 2014 | Bodum 10709 Toaster
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Kenwood TTP102 2Slice Toaster Logo
23 people viewed this question
Top Kenwood Kitchen Appliances - Others Experts
ka4iup
ka4iup
Irene Tulloch
Are you a Kenwood Kitchen Appliances - Other Expert? Answer questions, earn points and help others
