Question about Nordic Track NordicTrack COMMERCIAL 1750 Treadmill
Tread belt will not move
When turned on, everything else works but the tread belt will not move
I have it all set up..programmed a work out...it starts to work..but the tread itself that you walk on wont run..what do I do?
From the User manual....here
http://servicedocuments.com/pdfs/_0005_SOLE/_0005_SOLE_01_Treadmills/003_OwnersManuals/2010_2011_SOLE/F63_F65_OM_810.pdf
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
Sep 14, 2014 | Sole Fitness F63 Treadmill
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
Treadmill only hums when turned on, tread does not work
Hello, it seem there could be something jamming the tread mill belt or the transmission gears coult be broken. There is a very good possiblity that the electric motor has goine south, it doesn't work, or seeze up might have to be replaced.
GB...stewbison
Oct 19, 2011 | Cars & Trucks
No treads on harmonic balancer. Should there be treads on the harmonic balancer because my serpentine belt came off and upon reinstalation properly I found that the belt had treads on the serpentine belt,...
the pulley on the crankshaft should have grooves in it for the belt, otherwise the belt will not turn. is the pulley broken off, get back to me. there are NO technical servise bulletins on this item,if you need more help get back to me, Thanks Ray
Dec 10, 2009 | 2001 Oldsmobile Aurora
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Your Problem: jazfit-750 Treadmill motor will not turn on
DEAR
AT FIRST YOUR MOTOR CONTROL BOARD IS DAMAGE
I can turn it by hand it turns smoothly and the tread moves fine and the belt from the motor to the tread is good
Mar 18, 2017 | Exercise & Fitness
Belt shifting/crooked and frayed on Proform 725 TL
in the back of the manual, it describes the adjustment for this. on the end of the platform (near where your belt is crooked) there is a hex nut. the manual says to turn the machine off before adjusting, i find it is much easier to do while the tread is still moving. turn it about a quarter or half turn one way or the other until the tread is aligned.
May 09, 2009 | RTO Bodyguard T200 Treadmill
Title: Treadmill Belt Problem
determine which side is off centered
If the tread is migrating from the left you need to adjust the tension adjustment on the right and side of the roller and make it tighter
Most adjustments are made by turning a set screw that moves the idler roller ( the roller that is at the end of the tread mill which is where you first get on)
TO ADJUST:
1 TURN THE POWER OFF AND UNPLUG AT WALL OUTLET
2 Locate the adjustment screw( remember you will adjust the side opposite the migration to tighten the roller)
3 manually force the treadmill belt over toward the proper path( I do this by taking my hand and sliding my fingers under the belt and lift the belt as I hand roll it
4 Turn the adjustment screw counter clockwise one revolution
5 plug in then turn on and see if it stays in place
6 Keep repeating the process ( steps 1,2,3,and 4 )
Jan 06, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack COMMERCIAL 1750 Treadmill Logo
93 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
