Question about Rainbow 75th Anniversary Canister Vacuum
Reset button on 2010 model - Rainbow 75th Anniversary Canister Vacuum
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
Where is the thermal reset button
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you epwill hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced.
Apr 10, 2016 | Riccar 2000 4000 series Upright High...
Reset button on Rainbow vacuum
There is not a reset button on this model
Apr 01, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Reset button dyson dc24
http://www.youtube.com/watch?v=akGLQ7UbctY
Nov 20, 2013 | Dyson DC24 Animal Bagless Upright Vacuum
Where is the reset button on my eureka canister vac
with out knowing the model # i can't say for sure. however most of the eureka canister vacuum's ive worked on do not have a reset button. If its not working is probably the cord or switch that has gone bad. hope this helps
Jan 14, 2013 | Eureka Vacuums
Model 6970 will not start have checked all hoses tried to locate reset button by sticker on back of machine; where is it?
The reset button is the little white button (approx. 1/16" inch wide) by the sticker.
Mar 24, 2011 | Simplicity Vacuums
Where is the dyson reset button? Mine is a Model 08 something. It is about 6 years old.
The DC08 does not have a reset button. (at least, UK models don't and you don't say where you are).
Feb 02, 2011 | Dyson DC08 Cylinder Bagless Canister...
Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
May 25, 2009 | Rainbow 75th Anniversary Canister Vacuum
Vacuum will not turn on
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Jan 31, 2009 | Vacuums
Eureka sanitaire SC412 thermal reset
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=658043 Generic problem for all Vacuums
Posted by 5star on Jun 09, 200
I need to reset the thermal reset button. I have never opened by back pack vacuum before. Does it have a particular color and does it have to be reset to a particular point or do I just press a button?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka / Sanitaire SC412 Thermal Reset. I would contact the manufacturer to see if your particular model # has one, just give them the model # and the serial #. So I suggest that you get an owner’s manual from the manufacturer on you particular model so that if happens again, you will be prepared. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
5855 Terry Fox Way
Mississauga, Ontario L5V 3E4
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
Rainbow 75th Anniversary Canister Vacuum Logo
21 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
