Question about IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 - Was typing and the ribbon stopped moving
  • 120 Answers
SOURCE: Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Posted on Feb 15, 2008
  • 3594 Answers
SOURCE: Wheelwriter 3500 only printing top half of letters
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
DickyO
Posted on Mar 20, 2008
  • 3594 Answers
SOURCE: IBM Wheelwriter 6 ribbon not advancing
Befor you put a nrw motor in try a few drops of light oil on the m
motor bearings (WD40 works well).
DickyO
Posted on Mar 25, 2008
  • 3594 Answers
SOURCE: IBM Wheelwriter 3 will not type
Probably the plastic cap on the print soleniod is broken. They are available from us for 15.00 but a little tricky to install.
DickyO
Posted on Jun 20, 2008
  • 329 Answers
SOURCE: IBM wheelwriter
Is the hammer moving at all? There is a rubber part on the I think left side of the ribbon hammer, down on the side of the printer. This will adjust the amount of impact. I really doubt if
this is the problem, but worth a try to look at. This part and I think it is a blue slide will move up and down to adjust the impact. Possible lubrication and there is a large spring that actually pulls that hammer forward, check to see if this spring is OK. Other than that electronic problems such as main board, printer motors, etc. Does hammer move freely by hand? Also mechanical binding in the printer... GOOD LUCK.
Posted on Jul 23, 2008
Ibm wheelwriter 3
there should be a "switch" on the right side of your keypad to move to the ink position
Aug 13, 2014 | Office Equipment & Supplies
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 3 - Cannot get the complete word - Middle part of word is white
Type on a two part form if the carbons are goog then you have a ribbon problem. Look at the ribbon. Do the letters overlap (ribbon feed) If they don't fall in a line near the center of the ribbon (ribbon lift) Check for folds in the ribbon.
DickyO
Oct 04, 2012 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5. It was typing light so I
The plastic print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Feb 25, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3
You probably have a broken plastic cap on the print solenoid plunger, they are available but a little tricky to install.
DickyO
Oct 07, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Sep 22, 2008 | Lexmark Wheelwriter 3 Typewriter
DickyO
Jun 20, 2008 | IBM Wheelwriter 30 Typewriter
DickyO
Mar 24, 2008 | IBM Wheelwriter 30 Typewriter
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
26 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
