Question about ITT Binatone K301 Cordless Phone
Writing gone on my handset faded away
Handset
Uniden D3098S I have 2 register hand sets #1 and #2 I have a 3rd one having trouble registerting it to the base iam 2 feet away from the base unit it says check base power & out of range
Registering a Handset
If you see a "not registered" message on a handset, you must register it to a base before using it.
1. On the base, open the menu and select "Register Handset"
2. On the handset, press and hold POUND (#) until the handset display says "Handset Registering" (about 2 seconds).
3. Wait until the handset display says "Registration Complete" (about 30 seconds), then pick up the handset and press eND/CleaR.
# If you don't hear a dial tone or the display says "Registration Failed" charge the battery completely, then try again.
May 12, 2016 | Uniden Lands Phones
How do I register new handset for AT&T cordless phone el51359
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Dec 30, 2015 | AT&T Lands Phones
One handset on our Panasonic KX-T7730 system has gone wrong. I can get a line on Co 1 and Co 2 but the Sp-Phone mode is always on. As soon as I switch back to Co 1 or 2 to speak direct into the handset the...
Swop the handset for another working one and see if you have the same problem. If it nows works on then its the handset that has gone faulty. if its the same then the extension on the system that has developed a fault. If you have any spare extensions (keyphone ones that is, then just swop the plugs on the system and the faulty extension will now be a new extension and should work ok.
May 23, 2011 | Office Equipment & Supplies
Extend rj-22 to 10 Km away
Is this on a business phone system? An RJ22 is the plug for a handset cord, is that what you want to extend? The handset????
PLEASE, be more specific.
Jun 24, 2009 | Lands Phones
One handset doesnt ring
There should be a ringer tone and volume control on the second handset. Sometimes there is a ringer on/off switch on the side of the handset.
If that doesn't work, then there is a possibility that the speaker is broken.
May 26, 2009 | Uniden Cordless Phone
The sound from my speaker fades in and out, but the handset works fine.
Since this problem just started, I would first check to make sure there is nothing stuck inside the mic's port. Also, if you have a fan on in the room, that can also cause your speaker to fade in volume.
I say both of these because if the phone thinks you're saying something, your speaker will fade in volume. Whether you're talking or it's just air noise, the volume will fade.
May 22, 2009 | Vodavi 30-Button XTS Telephone
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
Uniden powermax 5.8 handset
place both handsets on the recievers for 24 hours so they can register to there spots
Dec 28, 2007 | Uniden TRU8885 Digital Answering Machine
AT&T 9371 TELEPHONE HANDSET
I know that these were good phones, but time marches on. I would search the web to see if you can find one for sale. Try to Google and see if you can find one. But I think you might as well look at some newer models. Prices have lowered and there are many improvements now. The newest ones out are dect and they pickup less interferance.
Dec 11, 2007 | AT&T 9371 Cordless Phone
Registration
I am not sure if this is the same model as my phone, but I pressed the exit button and then pressed the select button. The display says something like, hold Base Page button, so do that, then the phone will beep, let you type in a handset name, and you are set to go.
Aug 06, 2007 | GE 21028GE3 Cordless Phone
ITT Binatone K301 Cordless Phone Logo
12 people viewed this question
Top ITT Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an ITT Lands Phone Expert? Answer questions, earn points and help others
