Question about Xerox Office Equipment & Supplies
Reset clear admin password Xerox M123
How to reset or clear admin password Xerox M123
SOURCE: how to reset a forgotten
PRESS # AND ACCSES SIMULTANIUS FOR 3 SECONDS
PASSWORD 1934
Posted on Oct 18, 2008
  • 2072 Answers
SOURCE: I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
Posted on May 04, 2009
wrinaldo
  • 185 Answers
SOURCE: RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Posted on Jul 31, 2009
SOURCE: Default admin password for Xerox Phaser 8550DX
Default admin password is 1111
Posted on May 03, 2010
SOURCE: How do I perform a factory reset on a Xerox device
lol m looking for the same thing if u have found the answer can you please post it here ?
Posted on Jul 21, 2010
How do I reset the Admin password?
The default ID and password are "11111" and "x-admin" respectively. When accessing the administrator menus on the copier the code 11111 is used. I couldn't find a way to reset specifically.
I believe you should be able to access the Admin Menu by pressing the System button on the operator panel. A password is required to enter Admin Menu when Panel Lock Set is set to Enable. To Disable the Panel Lock you will need a password. The factory default panel password is 0000. Hopefully you haven't changed that. This procedure is described in the manual on pages 315 ff. I believe from there you can go in and assign a new Admin password if required.
http://www.fujixeroxprinters.com.hk/downloads/uploaded/CM215_UserGuide_Sec_c3b3.pdf
Jul 25, 2014 | Fuji Xerox® DocuPrint C3055DX Laser...
How do a forgotten admin password on a xerox 7655
WorkCentre 7655 7665 7675 Online Support Solution Modify the Printer...
Solution : Modify the Printer's Administrator Password Using CentreWare Internet Services (CWIS) NOTE: This solution assumes the WorkCentre is configured and working properly on the network.
  1. From the computer, open an Internet browser window.
  2. Enter the IP address for the WorkCentre in theAddressfield, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Properties] tab.
    NOTE:If the Login screen is displayed, enter the user name in theUser IDfield, and the password in thePasswordfield, and then click on the [Login] button.
    The default username is "admin" (case sensitive), and the default password is "1111". If it has been changed or forgotten, contact Support.
  4. Click on [Security] to expand the list of options.
  5. Select [Authentication Configuration].
  6. Click on the [Modify] button for Device System Administrator Password.
  7. Enter a new password in theNew Passwordfield.
  8. Retype the password in theRetype Passwordfield.
  9. Click on [Save]. This will be the new password to log into the Control Panel and CWIS.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=143,E=0000000004704152929,K=9646,Sxi=4,Case=obj(3814)
Solution : Modify the Default Admin (Tools Mode) Password on the WorkCentre NOTE:The Admin (Tools Mode) password allows access to configure network and machine settings on the printer.Xerox recommends only changing the default Admin (Tools Mode) password if absolutely necessary. If the password has been changed from the default password (1111) and has been forgotten, a service call is required to reset the password.
To change the default Admin (Tools Mode) password:
  1. Press the [Log In / Out] button on the Control Panel. The Log In window will be displayed. See theRelated Itemsbelow for additional information regarding logging into the WorkCentre.
  2. Select [Security Settings] on the left side of the screen.
  3. Select [Authentication] from theGroupscolumn and then select [User / Administrator Accounts] from theFeaturescolumn. The User Administrator screen will be displayed.
  4. Select the [Account #] field, and then select account number 1 using the keypad on the Control Panel.
  5. Select the [Configure Account] button. The Configure User Accounts screen will be displayed.
  6. Press the [Clear C] button (several times, as required) on the Control Panel to clear the old password.
  7. Enter the new password using the keypad on the Control Panel.
  8. If necessary, place a check mark in the [System Administrator (Admin)] and [Account Administrator] check boxes, and then select [Save Account].
  9. Select [Close].
  10. Press the [Log In / Out] button on the Control Panel.
  11. Select [Logout] on the Touch Screen.
Apr 04, 2014 | Xerox WorkCentre M-24 Color Copier
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
My Xerox WorkCentre M123 does not enter in more ways administrator password is 11111 and x-admin right but as soon as I enter the settings Administrator freeze (crashes) same thing with Internet access,...
  1. Enter UI Diagnostic Mode.
  2. Press the Log In/Out button on the Control Panel
  3. Select System Settings.
  4. Select Common Settings.
  5. Select Diagnostics.
  6. Select NVM Read/Write.
  7. Enter location 700-171 and press Confirm/Change. This is the current password. You can provide this number to the customer, or set the location to the default value (11111) and allow the customer to enter a new number from Tools mode.
May 26, 2011 | Xerox Office Equipment & Supplies
HOW TO RESET XEROX M20I TO FACTORY DEFAULT SETTING
The closest that you can get to a full factory reset is by doing the following
First: Press the [Machine Status] key
Second: Using the Navigation Keys select [System Admin Tools] and press [Enter]
If the System Admin Tools have already been passcode protected, type in the password and press [Enter]
Third:Select [Clear Memory] using the Navigation Keys and press [Enter]
Click System Data and press [Enter]
You May want to click on each of the given options to make sure everything is gone.
reference: http://download.support.xerox.com/pub/docs/CopyCentre_C20/userdocs/any-os/en/UG_Eng.pdf
section 9 pg 24
Apr 04, 2011 | Xerox WorkCentre M20i All-In-One Laser...
May 02, 2009 | Xerox Office Equipment & Supplies
Centreware password on Xerox 7335
On mine it was the other way around username 11111 & Password x-admin
Jan 21, 2009 | Xerox DocuPrint 4517 Laser Printer
How to reset a forgotten admin password on a xerox 4150
PASSWORD 1934
Oct 01, 2008 | Xerox Office Equipment & Supplies
Fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Aug 02, 2008 | Xerox WorkCentre M123 Copier
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
