Konica minolta 7145 ... what is factory reset code, paper tray size on screen is not correct, please help me how to make this correct
  • 1003 Answers
SOURCE: Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Posted on Jan 13, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 158 Answers
SOURCE: I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Posted on Oct 15, 2009
  • 44 Answers
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Posted on Nov 29, 2009
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Where is the hard drive
check the following link, maybe it will help you:
http://diagramasde.com/diagramas/otros/7145-7222-7228-7235SM.pdf
Usually, the hard disks are located where all the boards are, due to the fact that hdd needs to be connected with this boards and if the wires are longer, interferences might appear.
If you need anything else, just drop us an email at office@bizhubreset.com
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 11, 2014 | Konica Minolta Bizhub 7145 Copier
Set print a3 paper
A3 is 11 x 17 paper in the inch world. place the paper in the paper tray adjust the guides then go to printer properties select correct size.
Jan 08, 2014 | Konica Minolta Office Equipment & Supplies
Dear sir my photocopier konica7255 have problem. it not display its trays on its tuoch pannel and trays are not in working condition. trays are seaming off. plz tell me how to on them
Turn off the auto tray switching (ATS) and auto paper selection (APS).
Make sure you are using the right size paper in the trays.
I would need to know more about which options are enabled/disabled on your screen to help further, so reply to this post if that doesn't work.
Also you can try a hard reset (turn it off, unplug it for 20 seconds, then plug it back in and turn it back on).
Feb 27, 2011 | Konica Minolta Konica-Minolta 4599161...
We have a Konica Minolta Di2010 - we are getting a message on the screen that read: "A malfunction was detected. Please call your tech rep with this code: C0920" What can I do to get the...
C0920 as per the Minolta Factory Service manual is caused by a tray 1 lift motor failure. In my experience with this code, it is usually caused by paper loading in the tray or something jamming the tray. Best solution is to remove all paper from the tray. Leave the tray open an inch or 2 and turn the main power switch off then back on. The main power is on the back of the machine NOT the one on the right edge of the operation panel. Once the code has been cleared then try a test copy by using one of the remaining trays. If it works correctly then re supply paper into the top tray 1 and then see if the code returns. If it does then either your lift motor is bad or you have something jamming up the lift plate in the paper tray. You can always leave that tray open and run the machine until you can get someone out to look at it. Most of the time tho, reloading the paper in the tray will solve the code.
Good Luck and Thank You for using Fixya
WheatlandServices
Dec 16, 2010 | Konica Minolta Office Equipment & Supplies
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
Machine will not work, it says 'direction for this OHP size is not supported. Please change to direction or set size larger than A4'.
Are you talking about the bypass tray? Or Tray#,1, #2, #3?
Check the trays and make sure the guides are tight to the paper.
Make sure the paper sizes are registering correctly.
push the utility button on the panel, then user setting, initial setting then factory setting, then press ok, then exit out.
Also in the user setting if you press the paper setting make sure that it's set to plain paper.
Dec 08, 2009 | Konica Minolta bizhub C250 All-In-One...
Looking for drivers for Konica Minolta model 7145...using MAC OS Snowleopard v. 10.6.1
the newest driver available for this machine is for the mac 10.4.x os and the readme file that driver says from mac 10.4.3 onward constraints are applied to unavailable combinations between paper size and paper feed tray
Oct 11, 2009 | Konica Minolta Office Equipment & Supplies
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Apr 02, 2009 | Konica Minolta Office Equipment & Supplies
46 people viewed this question
jasbo
jasbo
