Question about Amana Heating & Cooling
Fan blows slow can place on high fan and it doesn't change the speed
SOURCE: fan motor slow on a/c
If the fan motor has a capicator it could be bad. A bad cap will pull the motor down. If there is no cap then the motor beatings could be going bad. this can be checked by matching the motor amps with the rated amps on the unit information tag.
Posted on May 18, 2008
  • 50 Answers
SOURCE: Fan Stops blowing air
Isthis a window unit? It sounds like it. There could be a problem with your fan switch or the fan motor itself? Multi-speed motors can lose one speed at a time. It really sounds like the fan motor is bad. If the compressor starts in the cool mode, and the fan doesn't, the fan motor could be locked up. See, if you can spin the motor by hand? If you can, then something is bad within the motor. Now, if the motor has a capacitor, check for a loose or burned wire. Good luck.
Ajkill
  • 2035 Answers
If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
  • OR
    This could the problem the with short circuit or defective component you need to check :
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
  • Good luck....
    Posted on Nov 11, 2008
    SOURCE: My hunter douglas fan has
    I have the opposite problem.  My fan turns on during the night at high speed and sometimes turns on the light,too!  I've changed the frequency 3 times, but have to pay someone to do so, so I've given up and just unplug it at night.  My problem, so someone tells me might be that mine is not grounded.
    Posted on Apr 13, 2009
    SOURCE: Fan Speed Too Slow
    You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
    Posted on May 28, 2009
    3 speed fan barely changes speed
    You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
    When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
    Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
    If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
    Dec 07, 2015 | Cars & Trucks
    Have a 2009 Nissan Quest I can't turn the heat off. Just stays on a high level of blowing out heat .
    If you have a fan that has different speed settings (1234, or low med high etc) and the only one that works is high - then the blower resistor pack has failed. If you have a climate control unit (where you just pick a temp you want) then the fan is controlled by the heating system and it sets fan speed. If you have climate control style try lowering the temp to a lower setting (current temp in vehicle) and see if fan slows down. If not then climate control unit or fan resistor bad. If dial type and you get nothing on lower settings (only high works like mentioned above) you need to change blower resistor. It is located under dash near the fan itself. Look for small unit bolted in duct near fan with wire plug going to it.
    Feb 23, 2015 | Nissan Cars & Trucks
    Fan slow down and them high speed
    change the fan ASAP, since the zooming noise and the slow performance will affect even the processor and you might end up replacing the processor as well if it persists. So get the fan ASAP and problem will be solved.
    Sep 30, 2013 | Gateway GT5622 PC Desktop
    Fan only runs on slow speed
    The receiver in the fan housing may have failed.
    Apr 20, 2017 | Hunter Dryers
    2003 GMC Envoy Heater Fan doesn't always blow
    Your problem most likely is the resistor block. In order to limit the fan speed a reistor is placed in the circuit which will limit current flow to the motor thus giving you the diferent speeds. High speed bypasse the resistor to get full motor speed. Since you only get high speed it is very likely that the resistor block is faulty
    Oct 24, 2012 | 2003 GMC Envoy
    Do you know of a way to slow down the LOW speed fan setting on a Kelvinator KSE70HRA air conditioner? Low is very noisy and blows air like a HIGH setting.
    Hi, no, im sorry if it is on low already, it can't be changed to go any lower. The only thing I can come up with is the fan motored is wired wrong, and they have the high or med lead connected to the low speed, as it should run slow. On a central air system, there is a board that is in the indoor unit that shows the fan speeds, and they can be changed.I didnt look up your unit, and if it is a central air and not a window unit, you can change the speeds at the board. The wires are colored, blue is normally low, red is Hi, and blk or yellow is med. If this is a window unit, there is nothing much you can do. If you know anything about electrical, and you have a 3 speed fan, pull the cover to get to the switch back, and see what leads the have terminated to the switch. They may have it miswired. I wish you the best of luck,
    Shastalaker7
    A/C, Contractor
    Jun 12, 2011 | Heating & Cooling
    I have an 85 corvette. the problem is the air conditioning. I have it on high speed but the air blows out very little like if its on low speed. and the compressor and evaporator is new so what could it be...
    If your car has a cabin filter (check owners/service manual) it may be clogged.
    You may also have a vacuum leak under the dash causing the vent flaps to not open all the way.
    Jun 09, 2011 | 1985 Chevrolet Corvette
    1996 Ranger 2wd interior fan blows hi spd only
    Possible solution is to check the fan speed switch. These go bad and won't change the speed/ or function in the lower speeds.
    Dec 29, 2009 | 1996 Ford Ranger SuperCab
    Heating & Cooling Logo
    Top Amana Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Bill Long
    Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
