Question about Euro-Pro TO160L 1380 Watts Toaster Oven with Convection Cooking
Need the manual of mistral electric oven mo200c
Need manual for GE electric toaster oven model 898691 53
Try Googling (GE)(898691 53)(manual) without parens.
Sep 25, 2017 | GE Toaster Ovens
Tip
Timer Switch Failures
Many toaster ovens use a timer switch to operate the ovens. Many of them use very poorly made Chinese timer switches that make a very poor electrical contact internally causing them to get very hot and in cases will melt connector insulation and also cause wall plugs to get very hot. One in particular is part # DKJ/1-60 which is used in Black and Decker and other manufacturers ovens. Replacement switches are about impossible to find and B&D will be of no help finding one. If your timer switch has only 2 contact tab's on it, you can use this tip to repair your oven. If it has more that 2 contacts, you will need to find a replacement switch or ask a qualified technician about other switches that can be used.
A safe and easy way to fix the appliance is to replace the bad timer switch with a single pole single throw toggle switch. Make sure to get one rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually, but at least you will be able to use the oven and not have to worry about a faulty timer switch overheating! The timers are for convienience only and you have to turn the OVEN feature on and off manually anyway so all you're losing is the timer convienience for toast or whatever and the toggle switches are much safer too. The switches can be purchased at any electrical parts store or at many hardware stores for under $10. A cheap and safe solution to the problem!
If you feel the need for a timer and want to take your chances with a timer switch, there are a couple switches that you can use to replace the DKJ/1-60 switches. They are made for Delonghi toaster ovens and are readily available. One part # is 5218104600. This switch will work the same as the original but it only has about a 15 minute toast timer. Turn counterCW for OVEN ON like the original switch. You may need to use some mounting parts from the old switch depending on your particular oven. Another switch which has a 120 minute timer is part # 5218101800 but may be a little harder to find. Both of these look the same as the DKJ/1-60 and are about the same size with the bell on the back of the switch.
on May 07, 2010 | Toaster Ovens
I have 4 1132 Lincoln electric ovens. The 3 r at
What is the actual temp of the oven? Not what the display says? If the conveyor running normal? If so you just need a display board. Depending on what temp is there are many possibilties after that.
Sep 30, 2013 | Lincoln 1132-000-U 61" Electric Conveyor...
I would like a User Manual for my Farberware Toaster Oven FSTO400B
Contact them here and request a manual:
farberware-electric@saltonusa.com 1-800-233-9054
Thanks for choosing FixYa,
Kelly
Sep 20, 2011 | Farberware FST400 Toaster Oven with...
Need manual for Farberware convection broil oven model 4850
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For convection broil ovens try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FixYa!
Jun 22, 2011 | Farberware T490C 1500 Watts Toaster Oven...
What is the electrical rating of the Convection Toaster Oven Mdl #169127/169140 as the manual states that the extension cord should be at least as great as the electrical rating of the appliance. I will be...
most appliances that have heating elements are rated between 1000 to 2000 watts, which will give you a current rating of between 5 to 10 amps, check at the back of the oven for the ratings. use
the formula P=VI, P(power(w) and V(voltage) and I is the current(amperes). the cord will have a
current rating, go for around 15 amp rating
Jun 17, 2011 | GE 168947 Toaster Oven with Convection...
Have T4800 Convection Oven, need fan, motor and thermostat. Cannot locate any parts.
Not knowing where all you have checked, here is contact info for customer service for electrical appliances from Farberware: Electric Appliances
If that doesn't work, then here is an address that will give you a list of sites that carry oven parts:
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 16, 2011 | Farberware T490C 1500 Watts Toaster Oven...
I just bought the last euro pro electric oven at the local lowes, today. I opened box, and the only paper work in the box was product registration card for cuisinart. I need a manual for my machine. Can...
google.com and enter your MOD # and you can get it on PDF file to download this manual it costs to mail you another , if you know the guys at Lowes they might photo copy or give you another , good luck >
Dec 19, 2010 | Euro-Pro Toaster Ovens
I have a Bajaj Majesty OTG 1602T model oven toaster griller. i need the instruction manual and recipe book. how do i get it and where ?
Hi ,
If you need the bajaj OTG instruction manual, go to the bajaj electrical site and fill the customer service form in Contact US.
P.S - Personal Experience, their service was quick...which has made me a customer of theirs for life!!!
Nov 25, 2010 | Toaster Ovens
I need a user manual for a Euro Pro Extra Large Toaster Oven
It shouldn't be a problem. You just use it like a regular oven and like a regular oven, you have to watch what you cook the first few times to be sure how it cooks. A regular gas or electric oven will be off by up to 50 degrees EITHER WAY (100 degree variable) from the factory. Toaster ovens are generally accurate to within about 10 degrees of the setting. Mainly the time it takes to cook something will be the only adjustment you should need.
Feb 05, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
Euro-Pro TO160L 1380 Watts Toaster Oven with Convection Cooking Logo
85 people viewed this question
Top Euro-Pro Toaster Ovens Experts
Dave
Dave
eyecam
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
