Question about Siemens Heating & Cooling
RCR10/433 - GB receiver not working (following thunderstorm!)
I cannot get any LED to light up - is it likely that the thunderstorm has damaged my receiver?
Sound system keeps cutting off. Red flashing light over power button
Take it in to a Kenwood service centre. You can't possibly diagnose what has been damaged by the power spike. At least it is not totally fried and they usually are. You are lucky.
Aug 31, 2014 | Kenwood VR-405 Receiver
S5603 display light not working
the display light led or the driver ic for the led is damaged .. u can easily replace it at any service center.. this ic is not that costly just a couple of hours work may fix this problem
Aug 24, 2012 | Samsung Star 3G GT-S5603 (16 GB) Cell...
D945GCCR Motherboard: after a thunderstorm the psu got damaged so I repl...
Sorry, the motherboard has been fried - nothing you can do, it's dead. Replace it.
May 18, 2010 | Intel D945GCCR Motherboard
Chamberlain Liftmaster GDO just clicks, no lights no open/close
Pull the logic board and check it for burnt or missing traces on the printed circuit. Thunderstorms love logic boards.
Apr 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Powers up, all lights buttons seem to work, but no sound
This can happen. Lightening causes static charge that can be picked up by speaker wires. It is possible ONE of the amplifiers has failed.
To check, have the room quiet. Turn on the amp. After 5 to 10 seconds there should be a nice solid 'CLICK' from inside the amp. If there is no click, the unit is in safety mode. You will need a service shop.
Apr 17, 2010 | Sony STR-DE835 Receiver
Receiver tuner out after lightning strike
you more than likely have a F.E.T.(Field Effect Transistor) front end tuner,very susceptable to lightning or static charge damage, chech your home owners insurance, you might be able to repair or replace the tuner but it wont be cheap
Sep 26, 2009 | Onkyo HTR500 Receiver
Blinking Standby Light on receiver, no power
Unplug from power socket for few hours,most likely had a surge from storm and destroyed,either way will need to be serviced to evaluate damage if power trick does not work
Jan 05, 2009 | Pioneer VSX-915-K 7.1 Channels Receiver
Phone connection problem
Yes, it looks like the thunderstorm has damaged your DTV unit because the DTV unit should only go off hook as a means of dialing the DTV Company. I would have that unit replaced. BTW, do not try to repair that DTV unit. I work for a Telephone company in the Maryland DC area and I can tell you there are no serviceable parts inside and the unit is not your to do that anyway. So call the DTV Company and have then replace the defective unit.
Aug 31, 2007 | Samsung SIR-TS360 DirecTV DTV Receiver
Heating & Cooling Logo
95 people viewed this question
Top Siemens Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Siemens Heating and Cooling Expert? Answer questions, earn points and help others
