Question about Generac Electrical Supplies
Loss of Speed Control
Generac 13kW air cooled, LP vapor. After engine start, speed and voltage control is good (119 - 121 v) for about 5 minutes. Then speed and voltage begins to swing wildly (102 - 122 v). Stepper motor throttle arm linkage moves in conjunction with speed swings. Just installed new voltage regulator module but didn't change problem. Can't tell if throttle stepper motor is responding to speed changes or causing speed changes. Possible that control board is sending erroneous control signal to stepper motor? Interesting that it runs fine for 5 minutes and then goes to hell.
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a 13kw lp
This sounds like the stepper motor is failing with heat. Given the Hz signal is straight from the alternator.... a loss of the signal would intially cause the unit to overspeed. (Wiring from alternator to control board problem maybe... also heat related)
The only thing that made sense to me is a problem in the 10 Ohm freq sensors or the stepper motor.
Noting you have changed the control board and your still having overspeeds Look at the the Hz sense portion. I would bet your shutdonws are being initiated due to over-voltage vs over-speed. That you may have to sort out.
Sounds like a long day... of troubleshooting. 5 - 6 hours wait and then PANIC just to duplicate it!
Hopefully you have the service manual. I have the one for the 15Kw and Up.. but sense circuitry is pretty much the same.
Sense circuit...
* Measure resistance across any combination of orange, yellow, brown, or black should read approximately 20 OHMS.
* Measure from red to any other lead should read 10 OHMS.
* Testing from any lead to stepper motor case should read INFINITY.
Orange or black to Black or green One leg... 20 Ohms
Yellow or Red to Brown or white 2nd leg 20 Ohms
Again Stepper motor or sense wiring / windings... is where I think the problem lies.
Good luck and I am willing to keep taking stabs at this. 40 years as an electrican here.
Thanks for choosing FixYa,
Kelly
Posted on Sep 01, 2011
  • 16 Answers
SOURCE: generac portable generator over voltage even with new control board and regulator
is engine running at 3600 to 3700 rpm at full load. most small engines run at this speed.you can buy a small tach on ebay TINY TACH.. you have to know what the engine speed is
Posted on Mar 05, 2013
Generac over-speed fault
check your frequency of the ac, if this is high, then adjust the rpms.
If that is fine and it is shutting down, check overspeed adjustment on control board if it has it.
Jul 16, 2017 | Generac Electrical Supplies
Why doesn't it start?
gen sets have to be run at set rpms so that the voltage and cycles are correct for the applications
with the rpms as little as 100 rpms below requirement , the voltage will be down , causing a brown out which burns out electric motors and if the rpms are low the required cycles will also be off which affects electronic equipment
service the gen set and find out why the rpms are not at the set level
Jan 09, 2016 | Generac Guardian Air-Cooled Standby...
FANS WONT COME ON ,,ALL FUSES,RELAYS AND ELECTRIC FAN MOTORS ARE NEW,,THERMOSTAT IS GOOD,,WHERE IS ELECTRIC FAN TEMP SENSOR LOCATION
op
why not post symptoms first and not a barrage of parts.
must we decode that to a symptom,. kinda hard right.
I will not guess. what is wrong, nor what is not working on your car. now what fans you are talking about, up to 4 fans on cars.
cab blower fan (wild guess blower is ok) and so is HVAC, ?
radiator fans
Condenser fan.
my wild guess to , engine over heats?????????
if yes, the scan it first. no not last FIRST.
it dont work like you think its not a 1988 Samurai.
sorry,
on modern cars, they got smarter, the engine goes
gee the PCM knows water temp why have a fan temp regulator.
hark , now it dont. (saves cash on useless parts)
but has a relay , (well until you have my car and the relay is now 100% electronic, called a huge transistor)
we've used this tech in industry for years, but car makers just learning how still.
i digress. but evolution and history helps diagnosis.
what is there?
Ill look for you, ive posted this 100s of times
the book is 4 bucks to see online. the real deal
lets look now.
XL-7 (the dash matters big time)
answering for , overheats engine, and fans on RAD dead.
(some are staged, PCM brains... now. and also chain ops based on if A/C is on or not) facts.
first I see 2 fans... ok.
the next page shows nice block diagram of the fan system
yup, NOT Simple.
ill post those words for you.
"The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans receive positive voltage from the cooling fan relays which receive battery positive voltage from the underhood fuse block.
During low speed operation, the ECM supplies the ground path for the low speed cooling fan relay which is fan 1 relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the series/parallel relay which is fan 2 relay, and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. The ECM grounds the high speed fan relay, which is fan 3 relay, and the series/parallel relay, which is fan 2 relay through the high speed cooling fan relay control circuit. This energizes the series/parallel relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the fan 2 fuse 1 on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 16 km/h (10 mph). This is to prevent a fan from cycling ON and OFF excessively at idle.
end quote.
i bet you didnt scan it , like 99.9 % of all posters here dont.
DTC Descriptors
DTC P0480: Cooling Fan Relay 1 Control Circuit
DTC P0481: Cooling Fan Relay 2 Control Circuit
DTC P0691: Cooling Fan Relay 1 Control Circuit Low Voltage
DTC P0692: Cooling Fan Relay 1 Control Circuit High Voltage
DTC P0693: Cooling Fan Relay 2 Control Circuit Low Voltage
DTC P0694: Cooling Fan Relay 2 Control Circuit High Voltage
Diagnostic Fault Information
is the ECT showing overheat, yes no?
if yes, it must operate a fan or 2.
the book even covers all tests for fans dead, in a large truth table.
both the FSM and alldata.com have that, its no secret ,its published in 4 major places.
lets back up
if the engine coolant is low (no that side tank the engine and rad)
the ECT will lie. if that happens the fans may not come one
that is because the ECT is useless measuring air, for water.
that water must touch ECT for ECT to work.
this is FIRST
then scan the ECT does it show overheating, IT must if it IS overheating. fix that next if it lies to you,(IR gun in hand)
The system has staged fans.
i cant find the trip points in my crappyy online pages.
but is like 225f then 250f trips. is my guess...
about. if the engine over heats, check fuses first then scan it.
it will simply tell you why its bad.
eg, fan1 output dead.
or if you hot wire a fan and its dead, then it is.
(only on cars with non modulated fans,,hot wire them,else not.)
now the link to the 4 buck real book.
the non dash XL7 (my guess) you this pick yourself... cant see car.
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
this is how it really works
the ECU has software that decide trip points for fans.
hard coded, this is. based on how hot it is and if A/C is on not.
its way smarter than 1988 and better.
the DTC errors can see an open line, shorted to ground or stuck 12v.(runs all time error)
(tells you relay is good or not)
25839272-0kjd5huq4lpr130nt243wle5-3-0.jpg no scanner no joy , sorry, tis a fact.....
Aug 27, 2015 | 2007 Suzuki XL-7
I have an 05rendezvous,need to locate switches for cooling system,fans aren't co ming on & now I'm going to need a new radiator,cuz plastic broke.But it broke before fans gave out.Which I changed stat
The engine cooling fan system is controlled by the body control module (BCM) and the powertrain control module (PCM) or engine control module (ECM). The BCM performs the calculations as to how long, when and what speed the cooling fans should turn on. The BCM then sends a class 2 message to the PCM/ECM to engage the cooling fan relays. If there is a malfunction with the BCM, the PCM/ECM will control the engine cooling fans independently. The engine cooling system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM/ECM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 2 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 3 or S/P relay and the cooling fan 2 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The BCM and PCM/ECM command Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Important:: A 3 second delay occurs before the powertrain control module (PCM)/engine control module (ECM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Aug 08, 2015 | Cars & Trucks
Where is the radiator fan switch located on a 2002 oldsmobile intrigue
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G113. The relays are located in the underhood fuse / relay box .
So ,what's the problem Paul , car overheating ? Fans not working ?
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the right cooling fan. The ground path for the right cooling fan is through the cooling fan 2 relay and the left cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3-second delay, the PCM supplies a ground path for the cooling fan 2 relay and the cooling fan 3 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the right cooling fan. At the same time the cooling fan 3 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the left cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The PCM commands Low Speed Fans on under the following conditions:
When the A/C is requested and the ambient temperature is more than 50?°C (122?°F).
A/C refrigerant pressure exceeds 1310 kPa (190 psi).
The PCM commands High Speed Fans on under the following conditions:
A/C refrigerant pressure exceeds 1655 kPa (240 psi).
So
May 11, 2015 | Oldsmobile Cars & Trucks
I have a engine code p0505 on a 2006 harley flhx, what is that mean?
P0505: Loss of idle speed control.
Does it idle fast or rough? Fluctuates up and down?
Best guess: Intake manifold leak or your IAC (idle air control) needs cleaned, your idle speed needs adjusted.
Everything I can think of:
Bad/carboned up IAC, vacuum leak, leaking injector(s), contaminated fuel, TPS off ( throttle cable/TPS needs adjusted), battery voltage less than 9 volts, overfilled crankcase. VSS (Vehicle speed sensor) defective, it will disable idle speed control. Loss of battery power to to pin number 31? (sorry no manual handy for pin number) on the ECM.
Mar 03, 2015 | 2006 Harley Davidson FLHX Street Glide
Generac portable generator over voltage even with new control board and regulator
Mar 04, 2013 | Electrical Supplies
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Mar 29, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Van chevrolet venture 2000
Fifteen minutes! you have bigger problems than only the fans the fans are controlled by a thermo switch that is heated by the coolant, If you have no coolant the sensor cannot activate But fifteen minutes seems like you may have a headgasket problem and steam cannot heat the coolant sensor.OperationNotesThe electric cooling fan operates when the engine cooling temperature exceeds a certain value. The cooling fan on this engine is controlled by the Powertrain Control Module (PCM) . The PCM turns the cooling fan ON by grounding the coil of the cooling fan relays when certain conditions are met. When the A/C is requested, the cooling fan will also be turned ON.
Power for the cooling fan motors are supplied through Maxifuses(R). The cooling fan relays are energized when current flows from the fuses in the Underhood Accessory Wiring Junction Block, and through the relay coils to ground through the PCM. The Coolant Fan 1 Relay Control Circuit is grounded for low speed fans operation. During low speed fans operation, both fans run at a slow speed. The Coolant Fan 1 Relay Control Circuit is grounded for high speed operation. During high speed fans operation, both fans run at high speed.
IMPORTANT: When certain Diagnostic Trouble Codes (DTCs) are present, the PCM may command the cooling fans to run all the time. Perform the A Powertrain On Board Diagnostic (OBD) System Check prior to diagnosing the engine cooling fans.
For more information regarding the Charging System, refer to Charging System Description , and Charging System Circuit Description in Starting and Charging.
If a problem that involves the low speed cooling fan relay control circuit exists, DTC P0480 Cooling Fan Relay 1 Control Circuit should set. If the problem affects the high speed cooling fan relay control circuit, DTC P0481 Cooling Fan Relay 2 Control Circuit should set. A problem with the ECT sensor should set DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage, DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage, DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage, DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage. Any of these DTCs will affect cooling fan operation and should be diagnosed before using the Electric Cooling Fan Diagnosis.
For more information regarding the Cooling System refer to Engine Cooling Fan Description - Electric, and Cooling System Description in Cooling System.
Here is the electrical schematic and how it all is suppose to work,
If you need any further help please contact me Thank you,Randy If you find this information helpful please give me a good rating
www.aceautomotive1.com
Aug 16, 2008 | 2000 Chevrolet Venture
Electrical Supplies Logo
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Don  Farrell
Don Farrell
Ottoniel
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
