Question about Bushnell ImageView 111025 Binocular
Focus my bixoculars - Bushnell ImageView 111025 Binocular
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
My cable release is not working. It triggers the auto focus but will not take a picture.
Try setting the camera to M manual focus and manually focusing on the subject. Some combination of focus size and focus type may not focus unless the sensor sees a subject and is in focus. So if the sensor cannot see and know it is in focus it will not fire. If you subject is not moving then focusing in manual will ensure the subject is in focus and the camera can shoot.
Apr 10, 2010 | Nikon D300 Body Only Digital Camera
My photos look blurry not focused. Have tried turning off the auto focus and manually focusing. They are always slightly out of focus, why?
check and make sure you do not have the soft focus turned on. that will make the pictures "soft" in focus or seem out of focus.
Feb 03, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Appears in focus in viewfinder, but isn't
Change your focusing setting to spot focus. Then, focus on your main subject, keep the button half-way pressed while you re-compose the shot and then press it the rest of the way. Does that improve the shot?
Sep 21, 2009 | Nikon D100 Digital Camera
More info for poor focus problem
I don't know about any misaligned focus feature on the D80. Have you checked to see what focusing mode you are using, ie. single auto focus, closest subject, or wide area focus. Closest subject can really throw off your focus. I would switch to single auto focus mode. Another reason for poor focus would be dust on the auto focus sensor which is located under the mirror box.
Check on the focus mode, if it's not a mechanical problem, I'd be willing to bet that's what it is.
Jul 22, 2008 | Nikon D80 Body Only Digital Camera
Is the focus area switchable?
The focus area can be set for Wide Focus Area, or Spot Focus Point. When using the Spot Focus Point, the DiMAGE 7i offers "Flex Focus Point (FFP) " for controlling the position of the Spot Focus Point. This is a powerful tool for off-center subjects.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Bushnell ImageView 111025 Binocular Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
